vrei sati transformi din xp in vista ??
Vista Transformation Pack is a software utility that transforms Windows XP's appearance to resemble that of Microsoft Windows Vista.
VTP will transform your entire user interface, including a Vista-themed Boot Screen, Welcome Screen, and Visual Style, as well as new icons, wallpapers, and more.
Features of "Vista Transformation Pack":
• Boot screen
• Welcome Screen / Logon Screen
• New msstyles files (visual styles)
• New desktop and file icons
• New toolbar icons
• Progress Dialogs
• Sounds scheme
• System Tray icons
• New Wallpapers
• Windows Media Player Skins
Vista Transformation Pack 9.0 Keynotes:
- New 3rd-party applications
- ViSplore - Vista Glass explorer simulator
- Vista Drive Icon - adding free space percentage in your drive icon like Vista explorer
- Vista Rainbar - Lightweight Vista sidebar based on Rainmeter that even consume less resources than real Vista Sidebar
Improved 3rd-party applications
- ViStart - Files indexing for documents search, improved reliability and compatibilities
- ViOrb - Improved graphic and reliability (C++ re-written)
- TrueTransparency - Improved reliability with improved AeroStyle's glass border
- WinFlip - Improved stability and reliablity
New functionalities
- Setup personization - Allow customizing Vista experiences upon installation without access to Welcome Center
- Windows XP Service Pack 3 compatibilities - Now you can enjoy Vista themes after installation with Windows XP Service Pack 3
- x64 compatibilities - More secured x64 installation without getting hurt by incompatibilities
There're also a lot of bug fixes and refinements in the program but let's just keep it simple with these for now. You can experience the rest later by yourself.
Changes in Version 9.0.1:
- Added ViSplore in unsafe applications list (It's first beta version after all)
- Added restrcting applications don't meet the requirements from startup list (But not from installation so you can set it manually still)
- Added restrcting to set unsafe applications in Personalization page (Welcome Center only)
- Fixed Windows XP Service Pack 3 compatibilities (Even non-RTM version can apply so make sure you use official build 5512)
- Fixed "Do not show this welcome screen after restart" option bug that always keep program in startup instead
- Updated Vista Rainbar's launcher for constant waiting cursor activity issue
- Updated Vistalize basic desktop theme components to apply font and toolbar in Personalization
- Updated VisualTooltip default configuration to set area space in bottom from 30 to 0
- Updated WinFlip's configuration for higher reliablity and compatibilities with ViStart
Download :>>> nu pot sa va spun
doar va informez:) pt ca styti voi uni nus de acord
:agresiv:
Re: vrei sati transformi din xp in vista ??
cred ca nu am fost inteles bine,reciteste ce am scris aici [Only registered and activated users can see links. Click Here To Register...] ........... te rog
Cred ca packetul asta de transformare e cel mai prost pachet pe care il poti instala pe PC-ul tau, are zeci de programele aiurea care tot ce fac e sa foloseasca resurse aiurea, sincer daca vrei doar sa te uiti la calculatorul tau instaleazal , daca nu pune pe bune windows vista fiindca daca te descurci in el nu e chiar asa rau pe cum sa speriat lumea de el.....iar daca vrei sunt pachete bune pentru xp cum e alky+windows sidebar si windows blinds(chiar daca sunt total impotriva unei aplicatii care imi aduc aminte ca prin 98 imi omora saracu calculator :) ) + teme bune de vista , nu va instalati toate rahaturile.
PS: inca ceva ce am vazut , nu ca nu ar fi usor de trecut de firewall, invatati sa nu va mai bazati pe firewall-ul de windows....
ajungi pana la urma ca iti merge mai greu pc-ul decat cu windows vista pus pe bune...
Cred ca packetul asta de transformare e cel mai prost pachet pe care il poti instala pe PC-ul tau ....
subscriu !
1. daca esti addicted la tema de vista ... ia bricopack ... si e mult mai sigur ca acest pack !
2. incercati sa nu lasati prea multe programe in background ... acelea folosesc memoria chiar si cand nu le utilizati ! Run - MSCONFIG - STARTUP - si debifati tot ce nu vreti sa porneasca la bootare ! :)
acest pachet nuti transforma in vista ci doar it modifica temele si icoanele ca si style xp si AlienGUIse:). Aplicatiile iti raman aceleas de fapt e ca si o tema ......
Acum chiar ne-ai luminat !! hai termina stim toti ca nu transforma in vista , cum naiba sa faca asa ceva....in fine ...ideea e ca are o gramada de programele care sti ce fac? iti consuma resurse aiurea.Cum spuneam ajungi cu programelele alea sa emuleze un feel and look de vista da mere mai greu decat ai avea windows vista instalat..., in fine e ultimul post, din punctul meu de vedere acest pachet este o mizerie. In cazul in care faci parte din cei neordonati si care nu tin la sanatatea sistemului de operare , atunci baga frate garla programe deastea de rahat, mai ales cel mai bun program din pachet e truetransparency sau cum io zice. in fine, oamenii neordonati si care nu stiu sa isi gestioneze resursele si nu se pricep tind sa foloseasca acest pachet.
cam asa arata un xp optimizat la maxim ... cu aplicatiile normale si cu tema vista din ce am recomandat mai sus !
atunci uite un prog sa til ti curat,aranjat si fara erori
XP Repair Pro will scan and repair over 53,000 common Windows Errors
XP Repair Pro 2007 will scan and repair over 53,000 common Windows Errors.
Our unique and one of a kind technology repairs over 53,000 Windows errors and is guaranteed to fix problems on your system.
Using hi-tech and effective functions your system performance will be improved in a dramatic way. Windows and your software will run faster and your system will be more stable.
XP Repair Pro 2006 is the Most Comprehensive System Repair Tool on the Market.
An advanced Registry Cleaner finds and repairs system errors and incorrect information in the windows registry. An optimizer removes obsolete and duplicate entries that Windows and other programs leave behind.
It will fix random PC crashes, error messages and will improve system performance by
up to 750 percent.
After the system scan is completed you can view a complete list of errors that were detected and choose to remove which ones you would like or just let the Intelligence System determine which should be removed.
The Intelligence System not only detects errors, but also analyzes each error against the software installed on your computer to determine how that error may affect other software.
Here are some key features of XP Repair Pro:
- Scans Eight Key Areas of Your PC
- Enhanced Registry Deep Analysis
- A More Functional Scan Results Screen
- Enhanced Graphical User Interface (GUI)
- Improved and Streamlined System Optimizer
- Safely Repair Errors in your Windows System
- Improve System, Program and Gaming Performance and Stability
- Fast and Secure Scanning Algorithms
- Scans Your Drives for Unused Shortcuts
- Automated System Restore Point Creation
- Compacts the Windows Registry for optimized system performance
- Automated Repair Capabilities
code:
e ultima oara cand te avertizez sa nu mai pui seriale si crackuri,data viitoare zbori definitiv de aici
apropo pe la regulament ai trecut?
asa da :) la 18 procese intradevar ca e optimizat :)
dupa bootare se incarca strictul necesar ! si am si tema :) ! scoate cineva mai jos de atat?
