PLiĀ® Jade2 - DM800 31.01.2009
31.01.2009
Highlights:
- Tuxtxt 1.108, with teletext caching support
- Freesat EPG, thx to sousoux
- DVB-C, Network-ID scanning
- PiP zapping (note: only 7025 and 8000 supports PiP)
- Discrete On/Off keys
Warning:
- Online update from Jade to Jade2 is not supported, the feed has been renamed from
'jade' to 'jade2' (the changes are such that the online update cannot handle them)
- For editing a Enigma2 (HDTV) channellist, you will need a channeleditor which supports
fully the service4 type lamedb file, like for example: DreamBoxEdit 3.0 or Dreamset v2.20
Enigma2:
- EliteDVB repository December 23rd 2008
- PLiĀ® repository December 27th 2008
Drivers:
- Bootloader #61 for DM7025(Plus)
- 20081025 drivers for DM7025(Plus)
- Bootloader #70 for DM800
- 20081210 drivers for DM800
- Bootloader #70 for DM8000
- 20081209 drivers for DM8000
Plugins:
- Latest Henksat settings [Only registered and activated users can see links. Click Here To Register...]
- AIO Grab version 0.8
Skins:
- Converted to latest enigma2
Mounts:
- support to mount CF and/or USB from fstab (for picons)
Languages:
- Several translations updated
Support:
- Online update support (IPKG feed)
- Global satellites.xml updated December 26th 2008
(DVB-S: FEC = Automatic; DVB-S2: FEC = Normal)
Known general Enigma2 Issues:
- USB SD card detection size: (, -1MB free)
- Automatic mounts of a CF card fails: you can add it via 'fstab' which is located in /etc/
- First time entering PLugins menu: Mediaplayer : a known hotplug __init__.py problem
- Slow C-Band Scan in Asia: due to the empty feed transponders
- Network wizard: DM800 LCD screen is hard to read under several wizard settings
- Picons don't work on all satellites which contains different bands: due to the orbital position
of the various bands (S,C,Ku) (serviceref)
