Aici o sa gasiti pe toate versiuni lui MBOX CONTROL CENTER.
Mbox Control Center V1.0 Beta 2.7
- add G-line in test peer
- add stat.info
- change tabs to multirow when to small screen
- add Czech language
please backup your files BEFORE you use MCC !!!
Mbox Control Center V1.0 Beta 1.2
MBOX CONTROL CENTER Change log
BETA_1.2
- add Newcs Trace ( from Newcs version 1.30 )
- add SFTP (ssh)
- FTP/SFTP port can be changed
MBOX CONTROL CENTER V1.0 BETA_1.3
add SCP ( now you can choose FTP/SFTP/SCP )
add ecm.info
add restart Mbox
add filter options in Mbox Trace
add level0 cards are marked yellow
fix some trace bugs (focus when selecting listbox)
fix bug copy/past in Newcs Trace
Mbox Control Center V1.0 Beta 1.4
BETA_1.4
- fix restart bug for some box's
- add peer last seen online status
- change mbox.kill path
- add Path for mbox.cfg in settings
( YOU MUST SET THIS PATH BEFORE YOU CAN USE MCC !!! )
Mbox Control Center V1.0 Beta 1.5
- removed empty password check
- add sort on each grid
- add check for non hex value's in M-line
- add Telnet termulator ( Thanks to VisMan )
Mbox Control Center V1.0 Beta 1.6
- multiple start of mcc ( for multi Trace )
- add PID.info
- fix bug in Newcs cursor
Mbox Control Center V1.0 Beta 1.7
- add new option add.data (first try, hope i understand all options correct)
- fix tab sequens in settings tab.
- remove username empty check
Mbox Control Center V1.0 Beta 1.9b
- fixed ECM Trace filter
- change font in Telnet console
- fixed Telnet screen after resize
- change { } in { 0 } for C-line in add.data file
- add switch off chameleon2 in Newcs Trace
- add button "Level Normal" in Newcs Trace
- enbled clear button when not started Mbox Trace
- removed forbidden sids in add.data file
Mbox Control Center V1.0 Beta 1.8
- add Mbox version in statusbar
- add free line for options/lines in add.data
- add copy/delete in add.data list (right mouse click)
- add mcc.channelinfo in Newcs (shows channel name in Newcs trace)
Use the same channelinfo file as CCcam. Rename it to "mcc.channelinfo" (keep same format !!!)
You can edit/change/replace it yourself (path of mcc.channelinfo is the same as MCC.exe)
Mbox Control Center V1.0 Beta 2.1
- add Local settings, no FTP server needed, no Telnet possible ( for mbox.exe )
- add "Stop Mbox" button
- fixed ECM/PID screen when no ecm/pid
- new Slovak language (fixed some terms)
- new Romana language (fixed some terms)
- new German language (fixed some terms)
Mbox Control Center V1.0 Beta 2.0b
- fixed wrong text user/port in add.data C-line
- new polish language (fixed some terms)
Mbox Control Center V1.0 Beta 2.0a
- fixed display characters wrong in some languages
- add greek language
- Profile selection sorted alfabetical (text sort)
- add multilanguage.
- stores the window size and location (startup with last size, location)
NOTE: You can create your own language file. Keep same order !!!
When done put it in MCC/lang dir and restart MCC.
Sent me the file then i will add in next version.
BETA_2.3a
I lost my source code (got a virus) so had to use a backup.
Backup is from Beta2.1.
I made the same changes so it's back to beta2.2.
It could be you will need to enter all config settings again. (sorry!)
Please let me know if there is some different then the Beta2.3.
- disabled the Upload button for mbox.cfg and cwshare.cfg when empty.
This should prevent you to upload a empty config!!!
Look at the end of the English file for any new textlabels.
Just translate it and paste it in your own file (and sent me the new translation only new text)
Mbox Control Center V1.0 Beta 2.4
- fix the disabled Upload button.
- fix mbox.ver label not cleared when switching profile
- add Auto Reload every 3 minutes (not changeable)
- added Test Peer function.
First backup your cwshare.cfg. When done testing you need it to restore your cwshare.cfg.
Then select one or more peers that you want to test. ( THIS WILL CHANGE YOUR CWSHARE.CFG !!!)
Press the "Start Test" button and MCC uploads the new cwshare.
After this you must restart your Mbox server. MCC will ask if he must restart Mbox.
Mbox Control Center V1.0 Beta 2.5
- add read/write mg_cfg
- add P-line to cwshare.cfg (right mouse click on peer status)
- remove H-option in add.data file
