Nabilosat Enigma2 Black Hole - DM800 v0.7
What is new in this version 0.7 ?
Nabilosat Black Hole v0.7 is highly optimized to offer an HD skin with best performance, speed and reliability.
EPG LoaderUpdated OpenTV EPG Loader by MaxZ4
NEW EPG SEARCH FEATUREsOpen the TV channel selection list and use keys 1,2,3 and 4 to launch the new options
KEY 1 will launch the EPG Search for titles
KEY 2 will shortcut the single channel EPG. Move the cursor to select the channel and press 2
KEY 3 will shortcut Multi EPG.
KEY 4 will list the last search keywords. Use it to repeat previous or favorite searches.
NABILO E2 EPG - Enable/Disable Pop Up WindowA new setting is added to the Nabilo E2 EPG. Set it to NO if you want to hide the EPG download Pop Up window
NABILO INFO PANEL - HDD TemperatureA new information is added to the panel. Press the Blue button, then the Yellow button and select HDD temperature to check how hot your hard disk is.
NEW SKINHigh resolution skin HD-ONE by Matrix10
NEW HD BOOT LOGOSHigh resolution bootlogos by MaximoII
NEW WEB INTERFACEThis new image includes the latest version of the Enigma2 Web Interface.
Enigma2 CVS date16 January 2009 2.6 experimental
Drivers date10 December 2008
Second Stage #70
Plugins Date16 January 2009
Plugins will be available for download from the Addons Panel. Many thanks to our BIG brother franzjuve for packing them
NOTEYou can install this image to flash, without any further support.
You can install this image to multiboot. In this case,
you must have the Nabilosat Pure Flash 29DEC2008 installed to flash. This is necessary because the flash image must include the second stage #70
Nabilosat DM 800 Pure Flash dated 29 December 2008 is available
[Only registered and activated users can see links. Click Here To Register...] Main Function KeysButton 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time Shift
AddonsDedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD Enigma2 Analogic Clock
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
InfoCCcam Info
Memory Info
Available Space
Processes
Service Info
Hard Disk Temp
Enigma2 Settings
About
Save
Select/Start/Restart EMU
2) Green Panel
Shoutbox
Fast Plugin
AddonsAddons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
Scripts Many thanks to the Beta Testers Team
Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, nixus, robyhummy, snakie, DeepDiver
Credits
E2 Sky Epg loader integration by MaxZ4.
Matrix10 for the new HD One skin.
^^MaXiMo^^ for bootlogos.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not supported!
WARNING.This image includes second stage #70. Therefore, if you install it to multiboot, it will not work with any previous image in flash. If you install it to multiboot, you must install the Nabilosat Pure Flash DM 800 dated 29 December 2008.
ATTENZIONE.Questa immagine include il second stage #70. Quindi, se la installate in multiboot, assicuratevi di aver installato in flash la Nabilosat Pure Flash DM 800 del 29 Dicembre 2008. .
download :
