Cum fac sa mearga CCcam 2011/NewCS162 cu -RS232 Card reader extern Pheonix pe DM500,am tot cautat tutoriale dar..nimic!
Ma interesa pe CCcam/NewCS,am primit raspunsul corect in alta parte,multumesc mult!
sa ne zici si noua daca ai reusit sa pui al doilea card pe dm500 si cccam.cfg cu care ai reusit poate mai sunt useri interesati :drinks:
Se zice ca astea ar fi setarile:
se pune asta in cccam.cfg
SERIAL READER : /dev/tts/0 phoenix
SMARTCARD CLOCK FREQUENCY: /dev/tts0 3580000
Frecventa o pui in functie de card.
Multumim pe aceasta cale amicului @satwien...
acest lucru il citisem si eu pe rdi ... eu asteptam un raspuns detaliat de la @spaniolul :tv:
Cu aceasta configuratie mie imi merge interfata pheonix cu dm 500
#### Configuratie de Baza Client ####
SERVER LISTEN PORT : xxxxx
WEBINFO LISTEN PORT : xxxxx
WEBINFO USERNAME :
WEBINFO PASSWORD :
AU = yes
SMARTCARD CLOCK FREQUENCY: /dev/ttyS3 8000000
DISABLE EMM : yes
B: /dev/sci0 00
B: /dev/sci1 00
#BOXKEY: /dev/sc0 ptr nds sau nagra
PHOENIX READER PATH : /dev/tts/0
CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
CAMKEY: /dev/sci1 00 00 00 00 00 00 00 00
CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CAMDATA: /dev/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SMARTCARD CLOCK FREQUENCY: /dev/sci0 6000000
SMARTCARD CLOCK FREQUENCY: /dev/sci1 6000000
TRY ALL CHIDS : /dev/sci0
SMARTCARD CLOCK FREQUENCY: /dev/tts/0 8000000
TRY ALL CHIDS : /dev/tts/0
TRY ALL CHIDS : /dev/sci1
In interfata pheonix am un card de focussat
Sunt_Oltean74 confirma cele spuse mai sus,multumita lui @satwien merge cardul de focuss in phoenix!
multumesc pentru informatie :cheers:
