Nu are nici o soluţie de conectare SATA3, 5 HDD in cutie, cu o interfaţă cu sprijinul SATA1, 5? Dar, reducerea, sau unic.
I thing you are using google translate. Please write in english
Has no one solved the problem with the interface SATA1, 50 / SATA3, 5? But, reduction, or a proposal PCB?
use a e-sata to sata cable for extern*
maybe this is usefull for you
I am from Slovakia. Me was the fact that IP9xxxHD does not SATA3, 5. And eSATA is solved only by simply connecting cables, so that the HDD, which norecognizes to SATA1, 5, norecognizes nor eSATA. Simply because the chip has an integrated support only SATA1, 5. Therefore, I wanted to know if someone has solved this problem reduction.
At present, little is supported HDD and it is therefore necessary to deal with this problem. No HDD will not work forever and a year already on the market will no HDD, which worked in IP9xxx.
