Dreambox Getting Started For New Users
JUST GOT A DREAMBOX
Here is a few tips to get you up and running
WHAT WILL I NEED….?
First of all there are three pieces of software that you will need
DREAMUP
This software is an essential piece of software if ever you crash your box you will need this to get it up and running again with a NULL MODEM CABLE
FLASH WIZARD PRO
This software is used to install an image onto your dreambox, after you have installed your first image with dreamup, once you have installed the image you can also back the image up with this software, this is handy if any think goes wrong with your unit you have a back up image that you can put back on.
DCC
Dreambox Control Centre this software is used for putting cams & keys onto your unit and editing files etc.
HOW TO FOR BEGINNERS
Installing your first image
I always use dreamup for this connect the null modem cable to a com port on your pc then to the com port on the dreambox, untick the use network box at the top left of the page then click on connect, you will see the job status-progress bar fill up blue then it will ask you to turn the unit on saying connection prepared, at this stage plug the power cable into the unit.
Now you are ready to install your first image, but what I do is erase the firmware that’s already on the unit so click on erase, after about five minutes you will get a box come up on the screen with erased RESULT SUM =0
Now click on flash, you will get a browse option so tell this where the image is that you want to install i.e.: C:/mydocuments/ where ever the image is saved on your pc, select the image and press ok.
Now you will see the percentage bar start to fill on the job status progress, this takes about 15 minutes to complete. DO NOT remove the cable until you get a box come up with image installed RESULT SUM=0. after this you can unplug the mains and null cable from the unit.
Now your heart is racing to get it connected to the dish to see if it works.
Connect the lnb-scart-ethernet cable if you are using a router and the power cable last it may take a couple of minutes before you see any think on the screen.
The first thing you will see is a settings for your tv with PAL in it, press the green button on the remote to save this setting, now it will ask what language you want to set the box to, select your language then press ok, after this you will see starting common interface on the screen then the screen will change to satellite configuration with three options choose the option for what setup you have, once you have chosen your setup the screen will change if you have chosen a simple method you will see a bar with a satellite highlighted press ok on that and choose the satellite that your dish is point at and press ok, now you need automatic transponder scan, once you are on that select the satellite you want to scan press ok and it will find a valid transponder if it is a fixed dish, you will see a tick in the lock & sync and it will say a valid transponder as been found now press the green button on the remote to scan all the channels in.
If you have chosen the complex method you will see the next page saying many satellites via DISEqc rotor press the green button on the remote the next page you will see motor config untick the goto XX function then press the blue button on the remote this page is another motor config page on the left of the page you will see Mode: Satellite: Transponder: Direction: highlight the satellite bar then press ok on the remote, select a satellite for instance Hotbird and press ok then the transponder should already be highlighted press ok and select a strong transponder on Hotbird I use 11623/27500 V after you have selected the transponder press the down button on the remote to direction, now with the left & right arrow buttons on the remote you can nudge the dish east or west to that transponder, once you hit that transponder you will get an X in both lock & sync now press the green button on the remote to store that position in the motor settings, once you have pressed the green button you will come back to the same page again this time press the blue button on the remote transponder scan, select automatic transponder scan and press ok now you will see another page SNR AGC bars will be pretty full with a lock & sync and the top satellite will be highlighted scroll down to the satellite you have just had lock & sync on and press ok, it will say a valid transponder as been found now press the green button to scan in the channels.
The same procedure for other satellites.
HOW TO INSATLL A CAM
This is where the software DCC dreambox control centre comes in, the default name and password on a dreambox is Name = root Password = Dreambox open the software and select your language and choose the connection type for this I choose router, now you will see three pictures the PC – DREAMBOX –ROUTER with a thick line going to all of them, put your IP address of the router in the router for instance 192.168.1.1 if this is the correct IP the thick line will change green from the router to the pc, and it should put the pc IP in automatically leaving a red line to the dreambox, leave this software running, now go to menu on the remote and select setup then expert setup press ok on expert setup then ok again on communication setup, on the top right you will see a box with DHCP with the left or right arrow go up to this highlight it and press ok you now have a tick in the box also make sure the enable network box is ticked after this press the green button to save then exit back to a tv channel, when on a tv channel reboot your dreambox after its rebooted press setup then expert setup press ok on expert setup then ok again on communication setup and you will se the IP address of your dreambox, make a note of this and go back too DCC enter your dreambox IP in the dreambox part now you should have a thick green line to the PC-DREAMBOX-Router and exit DCC software.
For instance you have installed a Gemini Image, All the things you need to update your image are contained in the BLUE BUTTON. You can see this by pressing the BLUE button on the remote control & scroll down to addons, once you have selected addons press ok on the remote then scroll down to DOWNLOAD & INSTALL press ok again now you have all the downloads on the screen, the 1st one you see is CAM press ok then you will see all the cams that are available to download, scroll down to the cam you want to download then press ok on the remote, it should download very quick then you get a screen saying ready to install press the green button to save, and complete the same process to download further cams.
DM500 users like myself no more than 2 cams
The two I use are: - Camd & MGcamd
VAR FILE
By pressing the BLUE button on the remote control & scroll down to addons, once you have selected addons press ok on the remote the 1st addon you see is SETUP, press ok on setup this will show you how much free space and how much used space is in your var file.
AUDIO SETUP
By pressing the BLUE button on the remote control & scroll down to QUICK BUTTON SETTINGS, once you have selected quick button settings press ok on the remote then scroll down to audio and press ok, once you have pressed ok it will return back to quick button settings exit out of that now you should be on a channel, press the yellow button on the remote control and you will see what audio language is available for that channel select English * away you go.
lb romana ( google translate ):
Tocmai am primit un DREAMBOX
Iată cateva sfaturi pentru a vă aduce in sus şi să fie difuzate
CE voi avea nevoie ....?
Mai intai de toate, sunt trei piese de software-ul care va trebui
DREAMUP
Acest software este un element esenţial bucată de software-ul de avarie, dacă vreodată te caseta de dvs. va fi necesar acest lucru să-l in sus şi să fie difuzate din nou cu o NULL MODEM CABLU
Flash wizard pro
Acest software este utilizat pentru a instala o imagine pe dreambox dvs., după ce aţi instalat prima ta imagine cu dreamup, o dată ce aţi instalat imaginea puteţi, de asemenea, inapoi imaginea cu acest software, acest lucru este util dacă cred că merge orice probleme cu unitatea dvs. aveţi o copie de imaginea pe care o pot pune la loc.
DCC
Dreambox centru de control acest software este utilizat pentru punerea cams & chei de pe unitatea dumneavoastră şi editarea fişierelor etc
CUM SĂ pentru incepatori
Instalarea prima ta imagine
Intotdeauna mi-am folosi pentru acest dreamup conecta null modem de cablu la un port COM pe PC, apoi la portul COM pe dreambox, untick a utiliza caseta de reţea in partea de sus stanga paginii apoi faceţi clic pe conectaţi, veţi vedea starea de locuri de muncă -bara de progres umple albastru apoi vi se va cere la randul său de a spune pe unitate de conexiune pregătit, in acest stadiu, conectaţi cablul de putere in unitate.
Acum sunteţi gata să instalaţi prima ta imagine, dar ceea ce fac este de a şterge firmware care este deja pe unitate de aşa faceţi clic pe şterge, după aproximativ cinci minute, veţi obţine o casetă de vin de pe ecran cu şterse urma USM = 0
Acum faceţi clic pe flash, veţi obţine o răsfoiţi această opţiune aşa spune in cazul in care este imaginea pe care doriţi să o instalaţi de exemplu: C: / mydocuments / vreodată in cazul in care imaginea este stocat pe PC-ul, selectaţi imaginea şi apăsaţi OK.
Acum, veţi vedea procentul bar de a incepe să completaţi la locul de muncă, statutul de progres, aceasta durează aproximativ 15 minute. NU scoateţi cablul pană cand nu obţine o casetă de venit cu imagine instalat urma USM = 0. după această puteţi să deconectaţi cablul null magistrale şi de la unitate.
Acum inima ta este de curse, să-l conectat la antena de satelit pentru a vedea dacă funcţionează.
Conectaţi-LNB-scart cablu ethernet dacă utilizaţi un router şi puterea de cablu ultima poate dura cateva minute inainte de ai vedea cred ca orice de pe ecran.
Primul lucru pe care il veţi vedea este un setările pentru televizor, cu PAL in ea, apăsaţi butonul verde de pe telecomandă pentru a salva această setare, acum va intreb ce limbă doriţi să setaţi caseta de la, selectaţi-vă limba apoi apăsaţi OK, după aceasta se va vedea incepand de interfaţă comună pe ecran, apoi pe ecran pentru a va schimba prin satelit cu cele trei opţiuni de configurare alege opţiunea de configurare pentru ceea ce aveţi, o dată ce aţi ales-vă setarea de ecran se va modifica dacă aţi ales-o simplă metodă vă va vezi un bar cu un satelit evidenţiat apăsaţi OK pe care şi alegeţi-vă că antena de satelit este la punct şi apăsaţi OK, acum ai nevoie de transmisie de scanare automată, o dată pe care vă sunt selectaţi prin satelit pe care doriţi să o scanaţi apăsaţi OK şi-l vor găsi valabil de transmisie dacă este vorba de o antena de satelit de fix, veţi vedea o căpuşă de blocare & sync şi-l va spune ca valabil de transmisie fost găsit acum apăsaţi butonul verde de pe telecomandă pentru a scana toate canalele inch
Dacă aţi ales metoda de complexe, veţi vedea pagina următoare spune multe, prin intermediul sateliţilor DiSEqC rotor apăsaţi butonul verde de pe telecomandă, pe pagina următoare veţi vedea cu motor de du-te la obiectul de configurare untick XX funcţia apoi apăsaţi pe butonul albastru de pe această pagină de la distanţă este un alt motor de configurare de pe pagina de stanga paginii veţi vedea Mode: Satelit: Transponder: Direcţia: evidenţiaţi prin satelit bara apoi apăsaţi OK de pe telecomandă, selectaţi un satelit Hotbird, de exemplu, apăsaţi OK şi apoi de transmisie-ar trebui să fie deja evidenţiat apăsaţi OK şi selectaţi un puternic pe Hotbird de transmisie-am folosi 11623/27500 V, după ce aţi selectat de transmisie-apăsaţi pe butonul de jos de pe telecomandă pentru a direcţie, acum cu săgeţi stanga şi dreapta butoanele de pe telecomandă puteţi da un ghiont de antenei de est sau vest, pană la care de transmisie, o dată ce ai lovit de transmisie-vă că va primi un X in ambele blocare & sync acum apăsaţi butonul verde de pe telecomandă pentru a stoca că poziţia in setările de autovehicule, o dată ce aţi apăsat butonul verde te va intoarce la aceeasi pagina din nou acest timp, apăsaţi pe butonul albastru de pe telecomanda de transmisie de scanare, selecta transponderul automate de scanare şi apăsaţi OK acum se va vedea o altă pagină de SNR AGC bare va fi destul de complet, cu o blocare & sync şi a inceput prin satelit vor fi evidenţiate defilaţi in jos la tine prin satelit au avut doar de blocare & sync de pe şi apăsaţi OK, va spun ca valabil de transmisie fost găsit acum, apăsaţi butonul verde pentru a scana in canale.
Aceeaşi procedură pentru alte sateliţi.
Cum să INSATLL O CAM
Aceasta este in cazul in care software-ul DCC dreambox vine de la centru de control, numele implicit şi parola pe un dreambox este Nume = root Password = Dreambox deschide software-ul şi selectaţi-vă limba şi alegeţi tipul de conexiune pentru acest router-am alege, veţi vedea acum trei poze pe PC - DREAMBOX-ROUTER, cu o grosime de linie de gand să le de toate, pune-ţi adresa de IP de la router router 192.168.1.1 de exemplu, dacă aceasta este corectă a IP-gros se va schimba linia verde de la router la PC , Ar trebui să şi-o pune in bucăţi de IP in mod automat ies dintr-o linie roşie la dreambox, lăsaţi acest software să ruleze, acum du-te la meniul de pe telecomandă şi selectaţi setarea expert setup apoi apăsaţi OK expert setup apoi pe OK, din nou pe comunicare de configurare, pe de dreapta sus, veţi vedea o casetă cu DHCP, cu săgeată stanga sau la dreapta merge pană la această evidenţiaţi-l şi apăsaţi OK, acum ai avea un tic in caseta de asemenea, asiguraţi-vă că activaţi este bifată caseta de reţea după această apăsaţi butonul verde pentru a salva apoi ieşirea din spate la un canal tv, atunci cand pe un canal tv dreambox-vă după repornirea sistemului său de presă repornit setup setup apoi apăsaţi OK expert expert setup apoi pe OK, din nou pe comunicare de configurare şi se va adresa IP a dreambox, ia notă de asta mergeţi inapoi şi să vă introduceţi prea DCC dreambox de IP in parte dreambox acum ar trebui să aveţi o linie verde grosime de la PC-DREAMBOX Router-DCC software-ul şi ieşire.
De exemplu, aţi instalat o imagine Gemeni, Toate lucrurile trebuie să vă actualizaţi imagine sunt conţinute in BLUE BUTTON. Puteţi vedea acest BLUE apăsand pe butonul de control la distanţă & Addons pentru a defila in jos, o dată ce aţi selectat Addons apăsaţi OK de pe telecomandă apoi mergeţi in jos pentru a INSTALARE DOWNLOAD & apăsaţi OK, din nou, acum aveţi toate fişiere de descărcat de pe ecran, de 1st una pe care o vezi este CAM apăsaţi OK atunci va vedea toate cams care sunt disponibile pentru a descărca, defilaţi in jos la CAM pe care doriţi să le descărcaţi apoi apăsaţi OK de pe telecomandă, trebuie să descărcaţi foarte rapid, atunci veţi primi un ecran de a spune gata instala apăsaţi butonul verde pentru a salva, complet şi in acelaşi proces pentru a descărca alte cams.
DM500 utilizatori ca mine nu mai mult de 2 cams
Cele două am folosi sunt: - Camd & MGcamd
VAR FILE
Apăsand pe butonul ALBASTRU de control la distanţă & Addons pentru a defila in jos, o dată ce aţi selectat Addons apăsaţi OK de pe telecomandă de 1 addon vezi este Setup, apăsaţi OK pe acest setup vă va arăta cat de mult spaţiu liber şi de cat de mult spaţiu utilizat este in fişierul dvs. de var.
AUDIO SETUP
Apăsand pe butonul ALBASTRU de control la distanţă & scroll in jos pentru a QUICK BUTTON Setări, o dată ce aţi selectat butonul de rapid setările apăsaţi OK de pe telecomandă pentru a defila in jos apoi audio şi apăsaţi OK, odată ce aţi apăsat ok se va reveni inapoi la rapid butonul setări de ieşire din faptul că acum ar trebui să fie pe un canal, apăsaţi pe butonul galben de pe telecomandă şi veţi vedea ceea ce este limba audio disponibile pentru acel canal, selectaţi engleză * departe ai merge.
