Swap file for DM 600 7000 7020
Swapfile create and activate
To create a swap file on the Dreambox to make must first make a Telnet connection
Under Windows, Start, Run
Telnet enter OK
IP of the box and login
Then in the directory in which the swap file will be created. In this case:
/media/hdd.
cd /media/hdd
Now create a file, as an example 64 MB
dd if=/dev/zero of=swapfile bs=1024 count=65536
Now we have created a file named "swapfile"
The size in kilobytes specify :
64MB => 65536KB
128MB => 131072KB
Create the swap file from the "swapfile":
mkswap swapfile
Now we have made the "swapfile" to be the swap file.
Activation :
swapon swapfile
Disable :
swapoff swapfile
lb romana ( google translate ) :
SWapfile a crea şi de a activa
Pentru a crea un fişier de swap pe Dreambox de a face, trebuie mai intai să facă o conexiune Telnet
Sub Windows, Start, Run
Telnet intră OK
IP de la cutie şi login
Apoi, in directorul in care a swap fişier va fi creat. In acest caz:
/ media / hdd.
cd / media / hdd
Acum, creaţi un fişier, astfel cum a fost un exemplu de 64 MB
dd if = / dev / zero of = swapfile bs = 1024 count = 65536
Acum, am creat un fişier numit "swapfile"
Dimensiunea in kilobytes specifica:
64MB => 65536KB
128MB => 131072KB
Creaţi fişierul de swap de la "swapfile":
mkswap swapfile
Acum le-am făcut "swapfile" pentru a fi de swap fişier.
Activarea:
swapon swapfile
Dezactivaţi:
swapoff swapfile
