explicatii ..... config linii CCcam....
* The ‘no’
The 'no' means that you will not take EMM (Emu’s) from your peers. CCcam can do its own EMM work if you add a recent Autoroll.key and Softcam.key in the var/keys folder. Change to ‘yes’ if you want to receive peer’s emu.
* The ‘0:0:2’
The 0:0:2 means that you will only receive cards at a Hop 2 from your peers. Just decide how many Hops away you want to receive (1,2,3,4,5)
The rest will eliminate all known old and fake cards from your server.
2. You have to insert the following after the password of each F:line
2 0 0 { 0:0:3 } { } { } change-peer-ip.dns.org
The 2 0 0
* The 2 means that the peer will get all cards at a maximum of 2 hops away from you.
The first 0 means that the peer gets no emus from you.* Change to 1 to get peer’s emu.
The other 0 means that the peer is not allowed to send us emm. Change to 1 to take peer’s emu. Please note that there has to be a corresponding entry in the in the server you are sharing with.
* The { 0:0:3 }
The 3 means that the peer can share your cards down two further levels beyond his own level. (If you have servers who are not allowing you any reshare, you should change this number to 0 or 1)
* The IP or DNS address at the end of the F line
The IP Address at the end of the F:line makes sure that only the specified peer connects to your server. This may prove very useful with hackers!
* Restricting shares
If you want to restrict what your peers get, you have to configure your peer's F line to which you want to block a card in the following manner. The following example restricts Canal+ Digitaal Nederland (19E). You can change to whatever caid you want:
F: user pass 3 0 1 { 0:0:3, 0100:00006a } { 0100:00006a:07d4, 0100:00006a:07d5 } { } change-to-user's-ip
Therefore user will not be allowed to view Canal+ Digitaal Nederland (19E) (0100:00006a) but is allowed to view the following two channels on Canal+ Digitaal Nederland (19E): Rtl 4 (0100:00006a:07d4), Rtl 5 (0100:00006a:07d5)
* If you want to allow him to view Canal+ Digitaal Nederland (19E) but not to share it you have to add a ‘:1’ :
* F: user pass 3 0 1 { 0:0:3, 0100:00006a:1 } { } { } change-to-user's-ip
* The above settings should work well with most servers.
* Good Luck!
lb romana ( google translate ) :
De "nu"
De "nu" inseamnă că nu veţi lua EMM (UEM a) de la colegii de breaslă. CCcam pot face propriile sale de lucru EMM dacă adăugaţi un recent Autoroll.key şi Softcam.key in var / folder de chei. Schimbare de a "da" dacă doriţi să primiţi reciprocă a UEM.
* The'0: 0:2 '
De 0:0:2 inseamnă că veţi primi numai cărţi de la un Salt 2 de la colegii de breaslă. Doar decide cat de multe hameiului departe doriţi să primiţi (1,2,3,4,5)
Restul va elimina toate vechi şi cunoscute fals de carduri de la serverul dvs..
2a Trebuie să introduceţi următoarele după ce parola de fiecare F: linie de
2 0 0 (0:0:3) () () schimba-egal ip.dns.org
Cele 2 0 0
* 2 de la egal inseamnă că va obţine toate cardurile de la un maxim de 2 hamei departe de tine.
Prima 0 inseamnă că, de la egal nu se emus de la tine .* Schimbarea la 1 pentru a obţine de la egal al UEM.
Celelalte 0 inseamnă că, de la egal nu este permis pentru a ne trimite EMM. Schimbare la 1 pentru a lua de la egal al UEM. Vă rugăm să reţineţi că trebuie să existe un corespunzătoare de la intrarea in server de partajare sunt cu tine.
* De 0:0:3 ()
Cele 3 de la egal inseamnă că poate vă impărtăşesc alte două cărţi de jos niveluri de dincolo de propriul său nivel. (Dacă aveţi servere care nu sunt permiţandu-vă orice reshare, ar trebui să schimbaţi acest număr de la 0 sau 1)
* IP de DNS sau adresa de la sfarşitul liniei de la F
Adresa IP de la sfarşitul celui de-al F: linie se asigură că, doar egal specificate de dvs. se conectează la server. Acest lucru se poate dovedi foarte util cu atacator!
* Restricţionarea parts
Dacă doriţi să restrangă ceea ce colegii de breaslă obţine, trebuie să vă configuraţi peer lui F linie de la care doriţi să blocaţi un card in modul următor. Următorul exemplu restricţionează digitaal Canal + Nederland (19E). Puteţi schimba la ce vrei Caid:
F: utilizatorul trece 3 0 1 (0:0:3, 0100:00006 o) (0100:00006 a: 07d4, un 0100:00006: 07d5) () schimba-la-ip-utilizator>
Prin urmare, utilizatorul nu va fi permis pentru a vizualiza digitaal Canal + Nederland (19E) (0100:00006 a), dar este permis pentru a vizualiza următoarele două canale miercuri digitaal Canal + Nederland (19e): RTL 4 (0100:00006 a: 07d4), RTL 5 (0100 : 00006a: 07d5)
* Dacă doriţi să permiteţi-l pentru a vizualiza digitaal Canal + Nederland (19E), dar nu să-l impărtăşească, trebuie să adăugaţi o ': 1':
* F: utilizatorul trece 3 0 1 (0:0:3, un 0100:00006: 1) () () schimba-la-ip-utilizator>
* Setările de mai sus ar trebui să funcţioneze bine, cu cele mai multe servere.
* Succese!
