Add a record button to a DM500s remote
There is no "record" button on a DB500s remote control so you can only record using the timer function. But a record button can be "added" by modifying the rcdmxxx5.xml file (and as I recently flashed my DB I lost the record button and had to remember how to do it... hence this post).
Anyway, copy the rcdmxxx5.xml file from /share/tuxbox/enigma/resources/rcdm5xxx.xml and save it to your PC.
Make a backup of it.
Use the "edit > find" facility to search for RECORD and make the following change:
change:
<action name="record" key="record" flags="m" />
to:
<action name="record" key="mute" flags="m" />
After editing it save it to /var/tuxbox/config/enigma/resources/ as the original file is read-only () and can't be chmod'd with an FTP program.
You can now use the mute button when in DVR mode (the yellow button) to as a record button on a DM500s remote.
