1 Attachment(s)
Re: SatChannelListEditor 3.1
O noua versiune de editor
Traducerea automat facuta de google :
Channel List Editor for UFS821, UFS822, UFS910, UFS922.
Version 3.1
New features:
Supporting Enigma2 (V4 format settings)
Converting Enigma2 V3 settings after V4
Transponder editor for Enigma2
Channel editor for Enigma2
Bugs fixed:
Too many channels, no matching transponder found, because the frequency of 1MHz channels on the frequency of the transponder is different (UFS922)
Radio stations in the favorites after their total number in the list sorted. V3.0 was only for TV stations resolved. (UFS922)
Notes
In Windows, Microsoft. NET Framework 2.0 or later installed
Under Linux, the Mono Framework installed (tested with Mono 1.9.1, WinForms libraries may need to be installed with "sudo apt-get install libmono-Winforms *")
Salut,
Este pe undeva un post sau link pentru folosirea SatChannel 3.1
de conversie dintr-un fisier cu sateliti si canale xml de la o imagine originala 1.06 sau aaf 2.0x intr-un fisier xml pentru e2 ver 6xx?
Multumesc.
Spunea cineva intr-un topic: pui in options-settings-general UFS-910 daca ai o lista de la Kathy 910, incarci lista cu open, treci iar la settings si schimbi pe Enigma2 si gata- iti converteste automat, poti si salva directorul...problema e de conectare la receptor pt a le descarca, fiindca nu stiu ce sa scriu in campul Hostname de la setarile Enigma2 la SatChannelListEditor 3.1... poate stie cineva- mersi
adresa IP a lui kathy, 192.168.1.100 (daca n-ai schimbat-o)
te conectezi la box cu telnet
Dai c-da #uname -n
Iti returneaza numele boxului adica AAF-KATHI
Apoi te duci in fisierul hosts din windows pc-ul tau si pui linia:
IP-BOX AAF-KATHI
adica de exemplu
192.168.1.100 AAF-KATHI
Apoi te conectezi cu SatChannel dupa nume: AAF-KATHI
