1 Attachment(s)
Addons pentru Enigma 2 sifteam 0.1.0
Daca aveti instalat pe "Sifteam E2" si doriti sa aveti skin,emu,settings...adica ceva ca blue panel de la Gemini faceti pe pasuri care scriu mai jos....
First by ftp enter to var/ and copy there content from unpacked archive var/ from pc (this is config folder) after copy give chmod (attribute) 755 for all files inside config folder. Now by ftp copy folder "Fantactic" to: /usr/lib/enigma2/python/Plugins/Extensions/ After this give all files inside "Fantactic" folder chmod 755. Now just restart E2 (restart gui) and have fun with fully translated PKT panel Thx for great support PKT & Sifteam.
Functioneaza si am testat-o eu.
Re: Addons pentru Enigma 2 sifteam 0.1.0
New update of PKT panel (v1.7) :
- added Clock in standby (need E2 reboot [not only restart gui] for properly working
- steering Led (vfd)
- we can change brightness of VFD display
versiuna v.1.7 se face download prin buton albastru.
aica e versiuna in limba poloneza.Limba engleza o sa fie gata miine.
Nu instalati addon-urile de aici pe imaginea E2 SIF standard, nu vor functiona ! Lipsesc niste module din imagine care le are doar imaginea modificata !
Pentru asta trebuie instalata imaginea sif E2 modificata (cu panelul inclus) de aici:
functioneaza foarte bine asta plug in.Dar daca vrei sa instalezi emu si key trebuie sa faci un plic la var/ cu nume keys.Si dupa poti sa instalezi relaxat...
new update this mod to online dawnload:
The new update ver 1.14
I guess what many people waiting for:
- Added support for Phoenix by an adapter USB -> COM on the chip PL2303
modules compiled a colleague, of course, t4ndeta POINT
At last ipbox with E2 may serve as cardserver
PS Phoenix and key connected to a USB hub
PS2 needed a full restart box
Aici e si versiuna pt cine vrea sa il instaleze manual...
INSTALLATION: copy to root of the E2 filesystem. Telnet to your box and execute: tar xvf PKT_mod_1.14.tar.
WARNING: Menus in Polish language - still no released in english. After instalation you need to edit /var/config/link and change content to: ADRES=http://pkt.sat-elita.info/PKT/E2_IP_EN, after this go to update menu, to change to english
