Uboot pentru ipbox 91&9xx&9000
Acest e un nou bootloader pt ipbox 9000HD.Upload se face exact cum se face si pt un firmware.Dar aica dureaza mai putin.
Uboot 1.3.2 is basically same functionality with Uboot version 1.3.1.
but it added a text only on the front panel display when software upgrade using USB memory stick .
Uboot 1.3.1: USB UPGRADE -> ERASING -> FLASHING
Uboot 1.3.2: USB UPGRADE -> Loading -> ERASING -> FLASHING
Acest e un nou bootloader pt ipbox 900HD.Upload se face exact cum se face si pt un firmware.Dar aica dureaza mai putin.
Re: Uboot 1.3.2 pentru ipbox 900 si 9000
rectificare, mai intai folositi cu terminatia img, daca va da eroare atunci eliminati terminatia img. update-ul dureaza cateva secunde
2 Attachment(s)
A aparut acum oficial si pe site-ul celor de la ub-com usb_uboot_1.3.2_050908.zip
N-am apucat sa-l testez, pe varianta neoficiala schimba denumirea din ipbox in cube revo. S-ar putea ca pe aceasta varianta sa redevina la denumirea de ipbox
Cuberevo Series Config file.
Cuberevo Series Config file If you want to multi-boot, download attached usb_config.img.
Then press number button on RCU which you want booting mode.
Multi-booting support as below.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
ps. Oare vine AB enigma?????
Re: Uboot pentru ipbox 91&9xx&9000
am er 2, er 10 appoi pe ipbox91hd ............. pt el nu exista uboot?
