NDS cam emulator pentru SS2+phoenix
Pune te rog link-ul complet.....Eu nu prea am gasit fisierul. Si sint interesat de el...Quote:
Originally Posted by vid36 [Only registered and activated users can see links. Click Here To Register...]
Incearca asta:
NDSCam allows you to use your legal subscription card to see the channels
you have paid for and should not be used for any illegal purpose.
Features:
- Work with MDAPI based apps like AltDVB, MyTheatre, WatchTVPro, etc.
- EMM Support (tested on Viasat only)
- Buildin TT-Trick
- Supports KS Driver
- EMM and ECM logging
NEW in ver.0.0.0.3
+ Support for Sky Italia and some other cards.
+ Small changes in CAT and PMT filters.
+ WTVP returned wrong ECM pid now fixed.
- Still no support for ProgDVB because of the conflicts.
REQUIREMENTS:
- DVB-S/-C/-T tv-card (tested on SkyStar1 & SkyStar2 cards only).
- Phoenix programmer (crystal 3,57mhz or 3,68mhz)
- NDS subscription card (tested on Viasat and Sky Italy cards).
INSTALLATION:
NDSCam should work with MyTheatre, AltDVB, SkyView, WatchTVPro and some other apps.
Below you can see some installation samples and a few tricks for the NDSCam.
AltDVB:
1. Place NDSCam.dll and NDSCam.ini file into the Plugins folder.
2. Edit NDSCam.ini file.
3. I suggest you to set packet size to 184 for petter performance.
MyTheatre:
1. MDWrapper is required. Place MDWrapper.dll into the Plugin folder and NDSCam files into the MDPlugins folder.
WatchTVPro:
1. Place NDSCam.dll, NDSCam.ini and NDSCam.cache file into the Plugins folder.
3. Set DO_TT_TRICK value from NDSCam.ini file to 1.
4. If no luck, try to enable KS_DRIVER.
TIPS AND TRICKS:
- For AltDVB users, I suggest you to set packet size to 184.
That should eliminate the freezings and speed up the decoding process.
Multumesc de amabilitae ! Sa fii iubit !!
