Gemini Project 4.50 DM500 MaxVar
The Gemini Project 4.50 DM500 MaxVar
ATTENTION !
Install only on original box!
MaxVar Image!
Only running in flash (it has been only tested that way). Please do only use DreamUp and don´t forget the flash erase. Do not use other tools like FW or DCC.
Technical Infos:
* Enigma of: 06.09.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.104
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* added editor to configure the cron-daemon
* Little Apache (HTTP-Server based on HTTPD)
* Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
* Inadyn (Daemon for different DYNDNS-Services)
* Settings for syslogd
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* Random function for all kind of soundfiles
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
* Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
* Functions for SWAP (virtual memory). Create, delete, size and location.
EPG
* additional functions (e.g. dishnetwork, cache, location)
* search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
* Infos of the recorded movies can be shown without starting the movie
* refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
* autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
* Duration of current event in the programm overview ( Menu -> Info -> EPG)
* general information about the EPG Data (BP -> Info-> EPG-Settings)
* a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
* RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scripts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* change the settings for recording (before Time, after-recording time,, location and recover-function)
* Create your own satellites.xml including only the satellites you really need.
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* create password using the BP (BP -> Extras -> Pwassword)
* rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
* Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
* Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
Recordings:
* records into different folders ( the settings have to be done in the Timer-Menu)
* LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
New:
* import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
* Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
* Reorganised the BP main menu
* addition information can now be found in Menu -> Information (new optical appearance)
* Device-Manager for HDD / DVD / CF / USB
* reactivated the Jukebox (special wish of a very nice User
). Please install as addon.
* Drivers for USB-Cardreaders are now included in the Image but are not loaded!
Fix + update:
* Dreamnetcast (now you can use TV and Internetradio at the same time)
* RSS-Reader
* Weatherforecast (now with favourites management)
* SWAP
* User-Script
* have a look in the CVS
Interfaces WebIF:
[Only registered and activated users can see links. Click Here To Register...] (ZAHL = number of cam)
[Only registered and activated users can see links. Click Here To Register...]**y?typ=STR&...test&val=blabla
[Only registered and activated users can see links. Click Here To Register...]**y?typ=INT&...itedvb/int-test
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any k**s or softcams. Backups or other modified Images are not from us and won't be supported!
Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
The use of this Image is on your own risk.
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background. We assume no liability for direct or indirect damage.
Thanks a lot and have fun
Your Gemini-Team
Support: [Only registered and activated users can see links. Click Here To Register...]
Download: [Only registered and activated users can see links. Click Here To Register...] NECESITA INREGISTRARE!
Re: Gemini Project 4.50 DM500 MaxVar
aici nu necesita inregistrare ;) DOWNLOAD [Only registered and activated users can see links. Click Here To Register...]
ATTENTION !
MaxVar Image!
sal am si io o intrebare , imaginile care sunt MaxWar pot dauna clonbelor cu mac de original 09 34 xx xx xx ?
Daca MAC-ul clonei incepe cu 09 34 xx xx xx poti pune fara probleme orice imagine gemini.
Atentie , MAC-ul trebuie sa fie schimbat la nivel hardware (folosesti patchME).
