NLB 8340 ce face nou.....
AbCom IPBox9 Series / CubeRevo nlb image
Unofficial Custom release
Image mod by Dexter & pen1010b
**** Updated: 23 october 2008 ****
Features of NLB Image
- Onscreen panel for stop/start of most features found in webif and more.
- Customized startup, faster load times
- Added support for
external usb serial port (PL2303 USB-Serial)
- Added binary utils
- ssh / scp / sftp (client tools)
- fw_printenv / fw_setenv (uboot environment see/change)
- strace
- cron daemon
- alternative thttp daemon (not used)
- Emu included (in /data folder, Read-Only)
new updates should be placed in /var/bin .. (see name in [] )
- [newcs] newcs 1.62 (newest 23.10.2008)
- [incubusCamd.sh4] incubus 0.5 (newest 22.10.2008)
(DISABLE TIMESHIFT TO MAKE THIS EMU WORK!)
- [mgcamd130] mgcamd 1.30 for nordic viasat users
- [mgcamd] mgcamd 1.30d
( use 1.30 if you are viasat nordic user,
for faster channel switching)
- mpcs 0.9d
- [mbox.sh40] mbox II 0.4 Build 005 (3.10.2008)
- [evocamd] evocamd
- all key files should be put into /var/keys folder.
- Samba (Windows networking sharing)
- ftp / telnet / ssh server
- terminfo for top (primarily)
- USB multiboot (see below for details on how to use it)
- supports all_noboot images too.. (except AbCom image)
- WebIf (details below)
- Bootscript for loading at every startup
- /var/S59_bootscript and remember "# chmod 755" on script
WebIf
The webif is your control center of the NLB mod image.
Default login is: root and password: relook
If you need to update access table for ip addresses allowed to access webif, please
edit the /var/etc/httpd.conf
You find a line here ie.
A: 192.168.
Enter your network segment here, example
A: 172.24.
or a specific public ip
A: 212.242.1.12
Save file, and reboot box, and you got access to the webif.
- System information
* Processes - List current applications running on IPBox
* Change SWAP HDD - Activate Swap or disable it.
* CPU Info - get IPBox cpu info details
* System Boot information - output of "dmesg" startup of box.
can be used even if your box shows "PANIC".
- System options
* restart samba - restart windows sharing service.
* Samba status - Activate or stop samba/windows sharing services
* Change HDD filesystem - Choose between ext2/ext3 or existing.
ext2 filesystem will run FSCK (filesystem checks)
ext3 filesystem skips FSCK
* telnet status - Activate or stop telnet service
* ssh status - Activate or stop ssh service
* ftp status - Activate or stop ftp service
* Restart box - Reboot your box
- Firmware options
* Upgrade FW - Upgrade firmware from img file in /var or /media folder.
transfer .img file to /var or /media folder and select this option
to upgrade firmware.
* Multiboot - Read below for details
- USB options
* SWAP - activate or disable swap on USB key
* Format USB - format a usb pendrive/stick for use with box
- and for multiboot setup
* NOTE: USB Stick will be mounted on IP900 as HDD if above 2GB
And this means it cannot be formatted in webif on ip900.
* Mount USB - mount a USB stick on box, to access files on it
* Copy /var - make backup of /var to your usb stick
* backup db.dat to usb - copy your db.dat file to your usb stick
* restore db.dat from usb - restore db.dat (will be named db.dat.edited)
requires reboot to take effect.
* List contents of usb - list contents of usb stick, if mounted.
- IPBox options
* HDD/NFS media folder change - NOT ENABLED AS OF THIS WRITING!
* Change Fan - enable/disable fan in Ipbox.
* Show time in led - activate Time in VFD display.
* Change led - Change VFD brightness (0-7)
* stop sbox at next boot - will disable start of "satbox" application at next boot (debug)
* Assign color button - Read/Yellow/Green buttons can be assigned functions
most options above + more described below here.
WideScreen - stretch tv picture on TV's that do not do it automatically.
ecm info - show current ecm info on tv
hdd temp - Show HDD temperature on tv display
restart cam - says what it does
stop cam - -- !! --
Soft updater - run your /var/bin/soft script
* Change skin - Change the look of your menus in DGStation satbox application.
* Skin: Crash Blue
* Skin: Crash Grey
* Skin: Crash DeepBlue
* display HDD temp - show current temperature of HDD
- Emu
* Change mbox status - Stop/start mbox at next boot.
* Remember to use "change emu" also to choose this one
* Change mgcamd status - Stop/start mgcamd at next boot.
* Change emu - Select between evocamd / mgcamd / mbox , to be
automatically startup at boot.
* Stop Emu - Stop running emu.
* Restart Emu - Restart running emu.
* Change newcs status - choose to stop or start newcs at bootup.
* Change newcs config - Choose between both/upper/lower newcs default config
- this will overwrite your existing configuration.
* ECM - Show current ECM of provider.
* Mgcamd shares - show current connections
* Card stats - mgcamd status
* Info about cards - if gbox peer enabled, shows current list of cards.
- Keys update
* Sxxxx.Kxx Update
runs your /var/bin/soft script
EMU DEFAULT CONFIGURATIONS
mgcamd
included is a default config to run with newcs and
use internal card readers (activated default)
originally tested with Viasat and CanalDigital cards.
mbox
Tested with CanalDigital card.
Now includes 32100.list, 32101.list with default all channel opened.
evocam
is included, but there are no defaults for anything configured!
incubusCamd
is included, but defaults are still in testing and this is a beta release of cam.
USB MULTIBOOT
- Multiboot feature gives you the option to boot off a usb pendrive/stick, so you can
more easily place as many files you wish into the root file system, with the only
limit of the usb filesystem size.
- It also uses the USB key for /var storage, so each image will have its own setup.
- Removing the usb key, will cause box to boot flash image.
- USB key should be formatted in webif, before use
- other USB key cannot be used/formatted in webif, when you are running multiboot.
Instructions for usb multiboot
- Format a usb key in webif (USB Options - Format USB)
if used in DGS box during mp3 playback or photo album, it will not work.
- Wait for an OK from formatting (takes 30-60 seconds depending on size)
- Placing firmware on usb key procedure
- * For /media folder
- with ftp copy an .img file to the /media folder
- Only SifTeam / NLB images will work.
- * For /mnt/data folder
- mount usb key in webif (USB options - Mount USB)
- select Firmware Options - Multiboot
- in field "Enter name ...." write a suitable name for image
- in "Choose file to put on usb" select image to put on usb
- in front of img file you can see location of file.
- Press "extract" to extract image to usb.
- when finished (takes 2-3 minutes), reselect "Firmware Options - Multiboot"
- In bottom "Select USB bootimage to use" you can now see your image.
? if it is not shown and extract failed, make sure your usb was
formatted with a unix fs, ie. using format usb in webif.
- You can choose to "Change" and mark which image to load at next boot
or
- You can choose to "Delete" firmwareimage from usb.
- Selecting "Flash boot" will make box boot your flash / disable usb boot.
- Reboot box to start usb firmware.
Re: NLB 8340 ce nou face.....
face multe dar nu are sub la digi1 2
E un problem cunoscut.O sa fie rezolvat.In general toate subtitle DVB nu merge la ipbox...e un bug pt care DGS a promis ca o sa rezolva.
