Noul incubus camd merge cu cccam gbox newcs pe ipbox 900/9000
Asta sunt stirile bune!!!Stiam eu ceva de cccam de la ABCOM,dar nu am avut mai multe informatii.Pun pariu ca o sa apare impreuna cu Enigma...
Din ce am aflat o sa stie si "dual transponder decrypting" ceva care nu stia mbox inca....
La acest emu se lucreaza de doua luni. Se pare ca va fi inclus in enigma ca si addon.
Din ce se aude la forum-uri.Acest emu posibil o sa fie public la weekend asta.Ramune sa vedem.Deja anumite persoane sunt beta tester la el...Iar enigma se aude pt 22/10 ca o sa fie public impreuna cu ipbox 910HD.Eu sunt putin conservat la toate asta anunturi..Dar numai ABcom stie....
Se zice ca va merge si pe Kathy ! :D
In exlusivitate pt membri lui RSP forum prima foto cu INCUBUS care stia cccam!!!O sa lucreaza la DGS receptoare si la fratii lui cum e ipbox si Darkbox.Pt kathrein nu cunosc daca o sa merge pt ca asta emu e evoluat pt Receptoare DGS si pt fratii lui.In putin zile o sa fie public o versiuna Beta pt totii user.Portita pt cccam a fost dm100 receptor nonlinux care ruleze cccam....
exclusivitate
Available for processor types: sh4 (tested only on Cuberevo, Cuberevo mini, kathrein ufs910 with e2)
Use the e2 version on kathrein with enigma 2 on board, the other version on ipbox 9000/900 with dgstation firmwares
Card client for protocols: cccam, gbox, newcamd 5.20, newcamd 5.25, radegast old, radegast new, aroureos
.conf and .prio files can be inserted in the /var/bin directory, or in /etc, or in /var/keys
20/06/2008, V0.50, First public release
camd33 and camd35 is really much unstable so I think it's not yet ready for public,
asap it will be ready i'll publish it
This is the first release, you can't see any log on the console because
I don't wanna people read infos that could put them on the strange way.
However logs on console are really good to know if bugs are the cause of your problem or
simply if you are so noob to not be able to configure it correctly.
Read very well config files and don't say something you don't know.
This is not a fully working cam, some functions are not implemented/enabled because they are not ready for public and
I think people don't wanna functions that are working not really good as they expected!
(also this version is a beta version, but i wanted to put some hopes on people that believe a cam is better than othern one,
we have tested the cam on many decoders and we can say this cam is not bad at all also in beta and not full working mode :p)
So for the first release I choose to public only client side of the cam.
I want to thank raton_craquero for givin' me the possibility to know really a lot of things on how to use dvb_api and i have
to admit that i really like his config file structure and his log functions, so i decided to use them with his agreement
Thank you!
Regards, the IncubusCrew!
1) Facem download pe file
2) Dezarhivam pe files
3) punem pe toate trei files la va/bin la var/keys si la var/etc
4) facem atribute 777 pe toate 3 files la toate plicuri unde sunt.
5) deschidem pe file incubuscamd.cfg
6) mergem la sfarsit de file si schimbam pe linia cu rosie.Asa:
ipbox este username care avem de la server
pass e parola care avem de la server
@192.168.1.4 e adresa dynds care are server sau local bagam asa 192.xxx.xxx.xxx
:10000 e poarta lui server.
[Servers]
card_server_url_0=cccam://ipbox:pass@192.168.1.4:10000
#card_server_url_1=gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>
7) Salvam ce am modificat si bagam inapoi la plicuri.
8) Dam restart la ipbox.
9) pornim pe telnet scrim cd var / keys
10) scrim incumbusCamd.sh4 si porneste si decodeze.
Pt ipbox folosim pe incumbusCamd.sh4
Pt kathrein cu enigma pe incumbusCamd.sh4_e2
Pe youtoube apare un filmulet cu enigma pe el, voi stiti de asa ceva , exista ?
de unde se poate downloda?
inca nu e publicaQuote:
Originally Posted by lucrad [Only registered and activated users can see links. Click Here To Register...]
se discuta aici
