Ce presupune partajarea unei cartele zaharoase?
Ce presupune sh4r1ng-ul unei cartele D*lce intr-um DM500?
Se poate face?
Ce mai trebuie facut in afara de scoaterea cartelei din conserva primita si introducerea ei in Dreambox?
Am incercat sa caut dar nu am gasit nici un topic relevant. Daca exista totusi va rog sa-mi pasati un link.
Re: Ce presupune partajarea unei cartele zaharoase
Se poate face?
sut cam multe facute ptr cardul zaharos dar celmai simplu fara complicati este punerea lui in CCcam unde face si au
Pur si simplu?
Plug & play?
Pur si simplu?
Plug & play?
SERVER LISTEN PORT : 12000
WEBINFO LISTEN PORT : 12001
#WEBINFO USERNAME :
#WEBINFO PASSWORD :
AU = yes
SMARTCARD CLOCK FREQUENCY: /dev/ttyS3 8000000
DISABLE EMM : yes
B: /dev/sci0 00
B: /dev/sci1 00
BOXKEY: /dev/sc0 XX XX XX #bexkey
#PHOENIX READER PATH : /dev/tts/0
CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
CAMKEY: /dev/sci1 00 00 00 00 00 00 00 00
#CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
#CAMDATA: /dev/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SMARTCARD CLOCK FREQUENCY: /dev/sci0 6000000
SMARTCARD CLOCK FREQUENCY: /dev/sci1 6000000
TRY ALL CHIDS : /dev/sci0
#SMARTCARD CLOCK FREQUENCY: /dev/tts/0 8000000
#TRY ALL CHIDS : /dev/tts/0
TRY ALL CHIDS : /dev/sci1
cam asa pui in CCcam si daca vrei poti sa pui si phonix
