Aica o sa gasiti pe PCeditor pt ipbox 91&9xx&9000
After a badly needed timeout here is the new PCEditor 1.2.46 Beta 10:
- New: Support for database revision 7934 (Image Revision 8022 or later)
- New: Update database R7327 to R7934
- New: Settings entry for Power Mode (in HDD settings)
- Fixed: Wrong FEC data for IPBox 9000/CubeRevo when editing transponders
- Fixed: Select modulation and transmission for IPBox 9000/CubeRevo when
- Fixed: Crash when dropping a favorite at the end of the favorite list
Asta sunt drivers care cere calculator cind e conectat pt prima data ipbox.
Asa cum am promis am facut si pe traducere in limba romana pt PCEditor.Mai jos e o versiuna beta cu care puteti sa verificati pe traducere.In 3-4 zile o sa fie gata toate traducere!! a ramas foarte putine lucruri...
Changelog:
- New: Import of transponders from KingOfSat
- New: Greek language file by FIKOS67
- New: Romanian language file by OTHEITIS
- New: Creating an all_noboot image for CubeRevo mini/IPBox 900
- Fixed: Bug getting next number for channel order when creating new
channels for non CubeRevo/IPBox 9000
- Fixed: Database download for CubeRevo mini/IPBox 900 didn´t work
- Fixed: Database upload for CubeRevo mini/IPBox 900 didn´t work
- Fixed: Bug adding cable transponders
- Fixed: Crash when editing terrestrial region
- Fixed: Calculating correct next channel number when adding new channel
- Fixed: Problem creating terrestrial regions
- Fixed: Now it is possible to add terrestrial and cable channels manually
- Fixed: Adding terrestrial "transponders" is possible now
- Fixed: Adding cable "transponders" is possible now
- Fixed: Pasting terrestrial channels is possible now
- Fixed: Wrong csv export for R7934
- Fixed: Wrong satellite id for channel when cut/pasting cable channels
Plus a few minor fixes
Remarks: When importing S2-transponders from KingOfSat there is no
possibility to determine the modulation (8PSK, QPSK) of the transponder
from the import file. Maybe this has to be adjusted manually.
Acuma limba romana e si oficial la PCEditor....
Changelog PCEditor 1.2.46 Beta 11a:
- Fixed: Database download for CubeRevo/IPBox 9x didn't work
Changelog PCEditor 1.2.46 Beta 11b
- Fixed: KingOfSat transponder import for non CubeRevo/IPBox 9x databases
- Fixed: Finding no S2-transponders for CubeRevo/IPBox 9x when importing KingOfSat transponders
La versiuna asta daca mergeti la meniu Ajutor (help)> Despre PCEditor o sa vedeti si numele meu la Traducere in limba Romana.Asta forum e nr. 1 in Romania pt IPBOX...Multumesc pe Admin si pe celelalte copii pt ajutor....Asta e un premiu pt RSP forum.
Changelog PCEditor 1.2.46 Beta 12:
- New: Support for database R8118
PCEditor 1.2.46 Beta13
- New: Comparing database revisions while uploading channel database
- New: Messagebox, when database revision of image and uploaded database do not match
- New: Reorder Favourite Groups to have the same order in the image as in PCEditor. You find this option in the context menu of Favourite Groups.
- Fixed: Sorting favourite groups didn't work sometimes or showed weird sort orders
- Fixed: Sometimes uploading the channel database didn't work
PCEditor 1.2.47, 28.01.2009
- New: Search for new versions online and download them, see menu Help
- New: Support for receivers IPBox 91 HD, 900HD, 910HD, 9000HD, AB IPBox 200S, 250S, 350Prime, 4xxS.
- New: All existing receivers have their own label now
- New: New naming convention for downloaded channel databases and backup images
- New: Support for Neumo 3.1 database
- New: Support for latest Neumo settings
- New: Set the http port for the webif manually in the network settings of a receiver
- New: Audio mode is changeable when adding or editing a channel
- New: Change and save column order of channel list. Drag a column to its new location.
- New: Select custom grid background colour
- New: Create channel list for WebEPG
- Fixed: Problem detecting wrong image type when flashing by ftp
- Fixed: Possible problem when uploading a channel database with IPBox 910
- Fixed: Wrong settings for maturity control
- Fixed: Wrong message when importing transponders from KingOfSat import file
- Fixed: Several sorting problems in NITView Plus a few more minor fixes
PCEditor 1.2.48, 30.01.2009
- New: Import transponders from [Only registered and activated users can see links. Click Here To Register...]
- New: Choose receiver when downloading a channel database
- New: Added columns transmission and modulation for transponders in NIT Edit
- New: Auto adjustment of columns in NIT Edit
- Fixed: Possible problem flashing images via ftp for all receivers
- Fixed: Wrong context menu in NIT Edit
- Fixed: Calculating wrong frequency for HD receivers when importing from Dreambox
- Fixed: Problem detecting DVB-S2 transponders when importing from Dreambox
- Fixed: Wrong label in general options for "Search by substring"
- Fixed: Missing scroll bar for channels in NIT Edit
Changelog PCEditor 1.2.48.1:
PCEditor 1.2.48.1, 03.02.2009
- Fixed: Crash when using NIT Edit
Changelog PCEditor 1.2.49, 21.02.2009:
- New: Create new database revision 1.20
- New: Define custom telnet port
- New: Define custom ftp port
- New: Enter HDMI output format in Video Settings
- New: Switch in PCEditor Settings/General for detecting Wine
- New: Switch in receiver settings for automatic web interface login
- New: Select additional needed DLLs for Wine during setup
- Fixed: Wine: PCEditor can now read the channel database
- Fixed: Wine: PCEditor can now create image backups
- Fixed: Wine: Crash when hovering over submenu items of context menus
- Fixed: Wine: All languages are shown correctly except Arabic and Greek
- Fixed: Wine: Webif is working on HD receivers
- Fixed: Selecting all satellites/transponders in NIT Edit when adding a new satellite/transponder under Wine
- Fixed: Creating a welcome image for Relook 400s was not possible
- Fixed: Problem adding cable and terrestrial regions when no satellites exist
- Fixed: Sort order of favourites sometimes didn´t remain after changing it
- Fixed: Truncating the symbol rate at KingOfSat import
Important remarks:
First of all I would like to thank HarryZusch for his attention, encouragement, information and support
concerning PCEditor and Wine.
When PCEditor is used under Wine, you need to set the automatic wine detection, otherwise PCEditor
will behave as usual. Furthermore you need to set the option "No Ping when accessing Receiver" in
PCEditor Settings/General. If you want to use the webif under Wine, you will have to set the automatic
login for webif, otherwise PCEditor tries to open the webif in a separate browser. To make the automatic
login for the webif work, PCEditor needs to apply a registry patch for the Internet explorer. If this
registry key doesn´t exist, PCEditor asks, if it should be created. Without this registry key, automatic
login for the webif is not possible.
PCEditor has been tested under Wine with several distributions and several version of Wine:
Kanotix 2007 RC7 / Wine 1.1.14
Gentoo (stable) / Wine 1.1.12
OpenSUSE 11.0 / Wine 1.1.14
Kubuntu 8.04 / Wine 1.1.14
There are still known issues concerning Wine. If you find a problem that should be fixed, [Only registered and activated users can see links. Click Here To Register...].
