Nabilosat Darkstar II DM70X0 Enigma1
Vesti noi de la nabilo:
Re: In curand Nabilosat Darkstar II DM70X0 Enigma1
Skinul ala nu se poate adapta ptr dm 500 ?
What is new in this DarkStar II DM7000 ?
Updated CVS: 08 August 2008
The image has been completely recoded based on the latest CVS
Updated Skin by porto
New DarkStar II skin customized by porto
Enigma 1 Integrated 8 Days Sky IT EPG
Download 8 days Sky IT EPG, and have it integrated to Enigma1
EPG Event Search
Select a single channel EPG, press 0, enter a keyword and search for your preferred events
EPG Channels Selection
Customize the list of EPG channels to download. We reccomend to restart Enigma upon completing the selection
EPG Channels Update List
Update the EPG channels list when there are changes
Standby after reboot
Your DM will automatically standby after an accidental reboot, such as after a powercut
Scheduled Reboot
Schedule an automatic daily reboot
Network fix
This feature is for DM7020 versions
Updated OpenVPN Kernel Module
The OpenVPN module has been updated. Fully included in DM7020.Download from Yellow Panel for Dm7000
Warning Do not download the OpenVPN plugin from the Yellow Panel to DM7020
Main Function Keys
Button 1xOK = Light Info OSD
Button 2xOK = Extra Info OSD
Button Blue = Nabilo Blue Panel
Button 2xBlue = Nabilo Extra Settings
Button Yellow = Nabilo Yellow Panel - Plugins List
Button 2xYellow = Nabilo Yellow Panel - Addons Manager
Button Red = Current Channel EPG
Button 2xRed = Select Channel EPG or MultiEPG
Features
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
Enigma1 Analogic Clock
Channel Orbital Position
Signal SNR, AGC, BER
Infobar Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Extra Settings
Swap File Settings
Inadyn
Hard Disk Settings
Nabilo EPG Settings
Nabilo OSD Preferences
Nabilo Scheduler
Network Services Panel
NFS Server Panel
Mount Points
System Info
Dreambox
Mount Points Info
Process Info
Memory Info
Enigma Setup
Bitstream
Save
Select/Start/Restart EMU
2) Yellow Panel
Forums
Shoutbox
Addons
Scripts
Addons Download Manager
Manual Install Panel
Addons Uninstall Panel
Images Uninstall Panel
Nabilosat Statistics
pentru dm 7000
si pentru dm 7020
Re: Nabilosat Darkstar II DM70X0 Enigma1
Salut. Ma poate ajuta cineva?Am instalat imaginea Nabilosat Darkstar II pe un DM 7020, pe compact flash.Gbox-ul am luat de pe serverul lor. Am si o cartela d***, care cu GP 4.50 e pusa in sharing cu combinatia mpcs+newcs+gbox. As vrea sa mearga si cu imaginea Nabilosat Darkstar II , dar degeaba copiez scriptul in folderul var/script , nu-l vad. Am numai common interface, si gbox-ul care am luat de pe server.
Unde sa-l copiez scriptul ca sa mearga?Oare ar trebui instalata imaginea in flash, nu pe compact flash card?
In Nabilo nu ai scriptul Emulatorului plasat in var/script ca la GP. Cauta in var/etc (pt DM 500S) si acolo vei gasi un fisier "smartcam.config", deschide-l si vei vedea cam ce fel trebuie procedat...sau mai bine instaleaza un EMU specific pt Nabilo si vezi cum isi creaza fisierele de instalare in :
var/bin
var/etc/smartcam.config
var/uninstall
var/uninstall/cam
prin analogie incearca sa instalezi manual emulatorul dorit...nu stiu cat de inteles m-am facut, dar iti urez bafta ! si sa iti reuseasca din prima
var/bin
var/uninstall
var/uninstall/cam
Multumesc pentru sfat.Progresez.Deja vad scriptul, dar inca nu functioneaza.Mai incerc, dar astept si putin ajutor. E total diferit ca la GP.
