Radegast v.4.2 rel8 Supports Ipbox Now
NOTE: THIS IS LATEST RELEASE OF V4 LINE. ONLY REAL BUGFIXING FOLLOW FOR V4 AFTER REL8!
- [nds] - camcrypt refactored for endianess
- emm parsing fixed
- added support for new tur*** card
- [plugin] - changed API version to 4.15 (added reader api calls)
- added support for external reader plugin
- added support for forcing ECM to fail by skip futher processing
- [nagra] added support for MECM60 for prov 11xx, 05xx, 31xx
- [irdeto] - v2 emu ecm/emm support added (but *** managemment is not enabled)
- camcrypt BF refactored
- [NEW***D proto] - fixed nagra resharing
- fixed cryptoworks resharing
- added config option to not drop connection on unsupported commands (like NE*CS private extensions)
- fixed passing seca card UA
- [rdgd proto] - fixed bug when compatibility mode in client was used
- fixed parsing CAP data for v4 proto when no provider was given
- [mod-con-webmin] added reporting dynamically detected servers (using reflector protocol announcements)
- [reflector proto] fixed buggy behaviour when no STATIC shares exist
- [virtual card] changed positional parameters meaning. Now is "reader xx name = CAID:UA ROVLIST:SALIST (WARNING: incompatibility change!)
- [sharing] - fixed fd leaking when connect fails other then EINPROGRESS
- added last-resort routing (using fake 0xFEED CAID
- [phoenix reader] speed up communication (thx for bastlir), optionally enabled
- [conax card] - fixed using tuneled CAID
- fixed bug when conax CAID was higher then 0B00
- fixed SUB parsing (still only normal records)
- [cryptow] be smarter when detecting valid answer from card
- [sci reader] enabled in sh4 build because of Sandali's sci api compatibility layer on ipbox
