How to block fake and unused cards
THIS IS FOR Cccam.cfg IV ONLY TESTED ON Cccam 2.0.9
Here is very simple way to block fake and unused cards and id´s. all that is needed is to add this to the end of your cline like so. thats it.
Code:
no { 0:0:2, 100:3, 100:4, 100:5, 100:9, 100:c, 100, 100:f, 100:10, 100:11, 100:12, 100:19, 100:1c, 100:1d, 100:21, 100:25, 100:26, 100:31, 100:33, 100:34, 100:37, 100:64, 100:66, 100:67, 100:6b, 100:6d, 100:70, 100:71, 100:72, 100:73, 100:100, 100:8227, 100:beef, 100:ffff, 500:80, 500:500, 500:1570, 500:2100, 500:2500, 500:5500, 500:7000, 500:8000, 500:8c00, 500:8c10, 500:9c00, 500:a000, 500:c400, 500:c410, 500:e400, 500:10c00, 500:10c10, 500:10c20, 500:10c30, 500:11c00, 500:15000, 500:16400, 500:16800, 500:16810, 500:18c00, 500:19410, 500:1a400, 500:1ac00, 500:20a10, 500:20a20, 500:20a30, 500:20c00, 500:20c10, 500:20c20, 500:21510, 500:21570, 500:21c00, 500:22100, 500:22110, 500:50000, d00:4, d00:8, d00:14, d0c:c, d0c:10, d0c:14, d0c:18, d01:50, d01:54, d02:8c, d03:c8, d05:c, 1702:6a, 1800:4101, 1800:4901, 1800:7001, 1800:7101, 1800:7401, 1800:7501, 4a60:0, 4aa0:0 }
just add it to the end of and cline you are sent and it will block most unused cards and fake cards please not {0.0.2, at the beginning this is the hops as to which you are wanting to have its set to hop 2 if you want to have more hops change 2 for 3 or 4 and so on hope this helps whoever needs and uses it.
So when you are done your cline should look like this.
Code:
C: ip-or-addy port username password no { 0:0:2, 100:3, 100:4, 100:5, 100:9, 100:c, 100, 100:f, 100:10, 100:11, 100:12, 100:19, 100:1c, 100:1d, 100:21, 100:25, 100:26, 100:31, 100:33, 100:34, 100:37, 100:64, 100:66, 100:67, 100:6b, 100:6d, 100:70, 100:71, 100:72, 100:73, 100:100, 100:8227, 100:beef, 100:ffff, 500:80, 500:500, 500:1570, 500:2100, 500:2500, 500:5500, 500:7000, 500:8000, 500:8c00, 500:8c10, 500:9c00, 500:a000, 500:c400, 500:c410, 500:e400, 500:10c00, 500:10c10, 500:10c20, 500:10c30, 500:11c00, 500:15000, 500:16400, 500:16800, 500:16810, 500:18c00, 500:19410, 500:1a400, 500:1ac00, 500:20a10, 500:20a20, 500:20a30, 500:20c00, 500:20c10, 500:20c20, 500:21510, 500:21570, 500:21c00, 500:22100, 500:22110, 500:50000, d00:4, d00:8, d00:14, d0c:c, d0c:10, d0c:14, d0c:18, d01:50, d01:54, d02:8c, d03:c8, d05:c, 1702:6a, 1800:4101, 1800:4901, 1800:7001, 1800:7101, 1800:7401, 1800:7501, 4a60:0, 4aa0:0 }
Its that easy guys. !!!!!! NOTE this will only block most not ALL !!!!!!!!
