Running Gbox and CCcam on the same box
1st Script
copy this in gbox_cam.sh
CAMNAME="GbOx_CCcam"
USERNAME=""
ZAPTIME=8
CAMID=970
DVBSET=1
INFOFILE="ecm.info"
# end
# This method cleans up /tmp folder of gbox files
remove_tmp ()
rm -rf /tmp/*info* /tmp/*gbox* /tmp/*online* /tmp/*share* /tmp/Newcs* /tmp/atack* /tmp/debug*
# This method starts Gbox > CCcam (That order)
start_cam ()
/var/script/AES_Gbox.sh &
sleep 5
/var/bin/gbox &
sleep 30
/var/bin/CCcam_2.0.3 &
# This method stops gbox and CCcam and then calls the tmp cleanup method
stop_cam ()
touch /tmp/gbox.kill
/bin/prockill gbox
/bin/prockill CCcam_2.0.3
killall -9 newcs cs2gbox 2> /dev/null
remove_tmp
case "$1" in
start)
echo "[SCRIPT] $1: $CAMNAME"
start_cam
stop)
stop_cam
restart)
echo "Restarting $CAMNAME"
stop_cam
start_cam
"$0" stop
exit 1
esac
exit 0
rename ur cccam ver in CCcam_2.0.3 or CCcam_2.0.4 ,CCcam_2.0.5
and reboot
this scrip is for Gemini i have test it it works very will u have gbox and cccam together .
You just have to take care about the name of both cams. It must be the same as the cam files in your dreambox.
You need about 30 sec delay between the start of gbox and the start of CCcam : even if gbox starts first , CCcam will take your local card (it is faster) so you will appear with no local for your gbox partners.
