PLi® Jade Images Suite 20080713
[PLi® Enigma1] PLi® Jade Images Suite 20080713 Rev.5335 este ultima imagine pli , cine o poate testa sa ne dea si noua informatii , daca are bomba sau daca e mai buna decat celelalte img pli .
A new Enigma1 PLi® Dreambox release is available for download.
The Original Enigma1 PLi® Jade suite contains the following images:
PLi®-Jade-DM500
PLi®-Jade-DM500-Old-Framebuffer
PLi®-Jade-DM500Plus
PLi®-Jade-DM56x0
PLi®-Jade-DM600
PLi®-Jade-DM7000
PLi®-Jade-DM7020
See below for what's New, Fixed & Features since the initial PLi® Iolite release
[youtube]XVkE9at8Ydc[/youtube]
We think it is important to have a PLi® image twice a year available in summer and winter.
Therefore, we have decided to make a steady Release Candidate public.
As it is a steady Release Candidate, you might run into some unknown bugs.
Please report any issues or bugs on our forum, so we can fix it before the final release of Jade.
Highlights:
- EPG Search added
- Complete redesigned backup/restore menu
- Fully programmable Blue and Yellow buttons to any menu or Plugin/PPanel
- Complete redesigned network mount screen
- New movieplayer plugin as a full and better replacement for the VLCF plugin
- Permanent timeshift integrated in reco***ng and playing menu
- Global worldwide Picon Sets added per Satellite / Provider
Enigma1:
- CVS Repository June 29th 2008
- PLi® Repository July 18th 2008
- RC repeat fix
- Build non-LCD boxes without DISABLE_LCD, so binary plugins will work
- Don't shut the box down on fatal Enigma errors
- Enabled TimeShift for DM600
- 2nd stage bootloader: Auto reboot after flashing nfi (DM500+, DM600, DM7020)
- Improved BER
- Auto Adjust AGCR1 to improve BER after tuning (yet only available via the registry)
- Disabled fast zapping for DM500 and DM56x0
- Mount network mounts as first step so EPG can be on a network mount
Plugins:
- Build Streamts with large file support
- Install movieplayer by default on all boxes
General, openembedded images:
- Several ipkg improvements, speedups and bugfixes
- Ushare and djmount (uPnP mediaserver and client) added
Drivers:
- Added keyspan usb2serial driver (DM7020)
Skins:
- ePicon widget added, used by skin and multiepg
* (uses serviceref piconnames, auto resizes picons to specified dimensions)
- X-Line skin updated
SQLite:
- Updated to version 5.3.9
Network Mounts Fixes:
- If a network mount is edited in the web interface, it's automatically unmounted
- Use udhcpc config/deconfig script
* This solves the problem samba fails to start in case the DHCP assigns another hostname
Network Mounts Features:
- DM7000 allows NFS V3 mounts too
- Support for NAS devices which cannot handle cifs Linux extensions
- /VAR can be easily moved to a network mount
Web Interface Fixes:
- Several in web interface/movie source
- Several in web interface/remote control
- Several in web interface EPG
- PDA webif improvements by Jonc
- Updated working forum links in webif, now containing links to the PLi® wiki
Miscellaneous Fixes:
- Several TuxTXT bugs
- More support for the DMM keyboard at several places
- Better remote control support for fx2 games
- Several fixes for Tetris
- Fixed the unresolved symbols issue for various SoftCams
- Sample PPanel can be uninstalled now
- LCD output for PPanels fixed
- Capacity in harddisk menu fixed
- RSS configuration path
- Improved harddisk detection
- Satellite setup fixes for more then 80 active satellites
- Reco***ng and playing fixes if a network mount is unmounted
- For writing EPG data to a network mount
- Disable PIG on DM500+
- No longer use (part of) the reco***ngdescription for repeating events
* Just use the current date as additional description
* Extra info will be in the EIT file anyway
Miscellaneous Features:
- Default zapstream for streaming to a PC
- Removed: "Show installed PPanels"
* All PPanels are visible in the plugin screen
- Support for dropbear in CDK images (DM500/DM56x0/DM7000)
- Forward/backward skipping using the remote control number buttons
- "Blue button" completely integrated with Enigma Setup
* (Removed: PLiKey ppanel)
- EPG Search added
- Added menu for PPanel to call any Menu from a PPanel
- Support for opening PPanels using an URL
- Movie directory automatically created and automatic fallback to internal harddisk if anything fails
- Swap menu added for oe boxes
- Ipkg support in PPanel
- Added DISH LNB setting support in Satellite configuration wizard (at first boot)
OSD Fixes:
- Date in OSD fixes
- Cosmetic changes in the Timer Menu
OSD Features:
- OSD is aligned acco***ng to OSD offsets
DM500:
- CCcam Softcam updated to 2.09
Further:
- Thanks to ims for EPG Search, Movieplayer Plugin and several fixes
- Some EPG webif changes by Alphons (we've added it to the CVS repository)
- EPG Search based on Sourceforge Merlin project
Thanks to the PLi testers for several fixes and features
Support:
- Online update support (IPKG feed) for OpenEmbedded boxes (DM500Plus/DM600/DM7020)
- Global satellites.xml updated July 5th 2008
Many low level changes fixes and other updates...
Detailed info, Wiki, FAQ's, HowTo's, TechNotes and information about this and the previous PLi® releases can be found on the PLi® Website:
Am testat PLi® Jade Images Suite 20080713
Am testat PLi® Jade atat pe Clona cat si pe Original, ca prima impresie pot spune ca este impresionanta fata de variantele anterioare. Mult mai fiabila, imagine TV ceva mai buna fata de alte imagini concurente, dupa cateva minute de butonare daca ai o minima experienta cu Dream-ul totul devine intuitiv. O recomand din toata inima tuturor, mai ales celor cu Clone ca alternativa la GP si nu numai. Cu toate ca lipsa spatiului in var pe unii ii deranjeaza, pe mine calitatea PLi® Jade chiar m-a impresionat.
Re: PLi® Jade Images Suite 20080713
E mai buna decat celelalte versiuni dar ...spatiul liber e prea mic , si nici gbox/mgcamd nu pot sa il bag ptr ca nu am script si se incarca imaginea cu log-uri.
Bun,prea mic dar cat e totusi? Cat ocupa imaginea?
am vazut ca pt dream 500 sunt doua tipuri de imagini....care e diferenta intre ele?
sau cu alte cuvinte :
...daca instalezi aia care este fara "old framebuffer" si meniul are o nuanta verzuie - iti trebuie imaginea cu cuvantul-cheie "old framebuffer" :)
Salut,
Am instalat inaginea PLi Jade pe un DM 500-s. Sunt multumit de ea din toate punctele de vedere mai putin unul.
EPG-ul imi apare automat multichannel, si mi-ar place mai mult sa fie single channel.
Are cineva vreo idee in acest sens?
Merci.
Apesi butonul meniu si va schimba pe single channel.
Ca sa apara automat single channel.. nu stiu :)
Salut,
Merci.
I-am dat de cap. Succesinea de comenzi este;
OK -> simultam info+rosu -> apare lista de unde selectezi single channel sau multichannel.
Personal imi place mai mult ca Gemini.. usor de utilizat si exista variante care contin toate programele la zi ccam,mgcamd,scam,gbox,enigma etc..:cheers:
Nota 9/10.
