Tot caut de ceva timp un nou lnb cu flansa pentru parabolica si dau numai peste ciurucuri,aveti vre-o recomandare in afara de lnb invacom? multumesc.
PS. postati si linkul unde il pot achizitiona!:)
Inverto single: [Only registered and activated users can see links. Click Here To Register...]
Multumesc de link-uri,un lnb care sa mearga atat in banda C cat si in Ku ati vazut pe undeva?Quote:
Originally Posted by edisitaru [Only registered and activated users can see links. Click Here To Register...]
Nu merge linkul....Quote:
Originally Posted by bonou2 [Only registered and activated users can see links. Click Here To Register...]
Este ok! dar cine il aduce?Quote:
Originally Posted by dragsat [Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]PV 60€
iva no incluido
[Only registered and activated users can see links. Click Here To Register...] Referencia: LNBCKU01
BANDA C Y BANDA KU EN UN SOLO LNB !!!
LNB DUAL UNICO CON 2 BANDAS
BANDA C + BANDA KU MODELO BSC621-2
PUEDE SER INSTALADADO EN ANTENAS OFSET Y PRIME FOCUS CARACTERISTICAS:
PRIMER LNB DEL MUNDO QUE RECIBE LA BANDA C Y LA BANDA KU EN UN MISMO LNB.
DISEQ 2.1 INTEGRADO
1 Lamina de teflon
Incorpora Guia de ondas para antena Prime Focus.
Puede ser instalado tambien en antenas ofset.
Caracteristicas banda C:
Toma de DiseQc: 1
Entrada 3.4~4.2 GHz.
SALIDA 950~1750 MHz.
Frecuencia:5150 MHz.
Ganancia 65 dB.
Caracteristicas de la banda KU:
Toma de DiseQc: 2
Entrada 10.7~12.75 GHz.
Salida 950~1950 MHz banda baja.
1100~2150 MHz banda alta.
LO 9.75 GHz frecuencia baja.
majoritatea sunt ciurucuri, unele pot fi si bune vei avea emotii cu ele.
un invacom merge pe toata banda de frecventa, fara gauri de semnal.
Dar nu merge in dual band C-KuQuote:
Originally Posted by Bamboo [Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...] un alt link unde se gasesc lnc-uri care functioneaza atit in banda C cat si in banda KUQuote:
Pentru romania daca ati avea un link cu lnb dual band.....Quote:
