Vad ca incepand de astazi nu mai emit...s-au mutat pe Astra sau ce se intampla?
Cam da mai mult ca sigur, la scanare nu mai intra Multivision, naspa si este doar inceputul.:comp:
# (18h11) TPS: Multivision 1 has left 11662.00MHz, pol.V (DVB-S SID:1301 PID:120/130 French,131 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) TPS: Multivision 2 has left 11662.00MHz, pol.V (DVB-S SID:1302 PID:220/230 French,231 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) TPS: Multivision 3 has left 11662.00MHz, pol.V (DVB-S SID:1303 PID:320/330 French,331 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) TPS: Multivision 4 has left 11662.00MHz, pol.V (DVB-S SID:1304 PID:420/430 French,431 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) TPS: Multivision 5 has left 11662.00MHz, pol.V (DVB-S SID:1305 PID:520/530 French,531 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) TPS: Multivision 6 has left 11662.00MHz, pol.V (DVB-S SID:1306 PID:620/630 French,631 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) TPS: Multivision 7 has left 11662.00MHz, pol.V (DVB-S SID:1307 PID:720/730 French,731 original audio), it is no longer transmitted by satellite in Europe.
# (18h11) Noos Numérique & TPS: Multivision promo has left 11662.00MHz, pol.V (DVB-S SID:1309 PID:920/930 French), it is no longer transmitted by satellite in Europe.
Mesajul pe canale este : Arret le 02 juin.
In romana ar fi asa : oprite de la 2 iunie.
salut,
Am citit pe site-ul francez si se spune ca vor trece toate programele pe 19 est pentru a combate pirateria si chestii din astea.
Ca sa poti intra pe site-ul lor trebuie sa fii abonat al lor si deci prea multe nu am putut afla.
Aceste informatii sunt puse la vedere
Ce este clar este faptul ca vor cam trece pe 19 est toate cat de curand.
rasfoind in amanunt acelasi site, am aflat ca pana in toamna se duce tot tps
O parte din canale vor pleca treptat, iar certitudinea este ca ele dispar in totalitate din toamna. Aceste sunt lucrurile spuse pe net de catre ei, deci sunt adevarate din pacate, ptr moment
Originally Posted by mihai85 [Only registered and activated users can see links. Click Here To Register...]
Adica intra in faliment ? Ce rost mai aveau atunci sa le mute ? Sau poate ca e o ultima incercare ...cine stie.
