DREAMBOX 7000
DreamBox DM7000 technical data
2 DBS-Tuner:
Frequency Range 950 . 2150 MHz
Signal Level - 65 dBm . - 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK
FEC Viterbi and Reed-Solomon
Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
Roll-off Factor 35 %
Demultiplexing according ISO 13818-1
Common-Interface:
Common-Interface Power Consumption max. 0,3A/5V
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz
Video Formats 4:3 / 16:9
Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart)
Letterbox precolating for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 ∓ MPEG-2 Layer I and II
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS,RGB,S-Video over OSD selectable
VCR-Scart:
FBAS
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Function: Update of Firmware, Conntect to PC
USB:
USB 1.2 connector
Mini DIN:
I2C for stearing of external devices
IR funktion
Pins:
1 5V
2 SDA (I2C-Kanal 2)
3 SCL
4 3,3V
7 GND
8 IR-Output
9 GND
UDMA66 IDE Interface:
Intern for connect HDD max. 500mA
Compact Flash - Reader
LNB power and polarisation:
LNB Current 500mA max. ; short-circuit-proof
LNB Voltage vertical <14V> 11,5V at 400mA
LNB Voltage horizontal <20V> 17,3V at 400mA
LNB shut-off at Standby-Mode
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 20W (in operation, horizontal polarization / 400mA LNB current)
< 11W (in operation, without LNB)
< 2W (Deep-Standby-Mode)
Input voltage:
230V / 50 Hz alternating acurrent +/- 15%
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 374 mm x 230 mm x 75 mm
Weight: 1,8 kg without HDD
NETESTAT
NABILOSAT 0.1 IMAGE
Released 6.1.2007
[Only registered and activated users can see links. Click Here To Register...][/b]
si
Nabilosat Image v.0.4
NETESTAT
The Gemini Project 3.40 DM7000
Info Techniczne:
* Enigma of: 29.01.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6-Expert
* Busybox 1.2.2
* Tuxtxt V1.99
Re: DREAMBOX 7000
doua site-uri utile ptr cei ce se descurca cu engleza
Re: DREAMBOX 7000
Re: DREAMBOX 7000
Re: DREAMBOX 7000
arata, arata :) dar si functioneaza:drinks:
Re: DREAMBOX 7000
