How to cas2
programare cam cu cas2:
se introduce cam-ul in cas
se deschide cas studio
selectati cam module apoi cam-ul dorit
dati connect apoi erase all si asteptati pana se termina stergera flash-ului
apoi selectati open file si incarcati fisierul dorit, apoi click pe write si asteptati
cand s-a terminat scrierea, dati exit, scoateti camul din programator si fuga cu el in receiver.
Vizionare placuta!
ps: daca dupa erase va apar niste erori de genul "error in blank 3", se va repeta procedura de erase, apoi incarcati softul dorit
Re: How to cas2
Buna seara se poate reprograma un cam Aston seca in cripto sau viacces multumesc anticipat .
Re: How to cas2
nu stiu sigur, dar ma interesez pentru tine
Re: How to cas2
m-am interesat dar raspunsul nu este unul pozitiv, imi pare rau.
Re: How to cas2
uite si o varianta promitatoare
This is a quick help file to run through upgrading your Aston/Cryptoworks CAM using Windows 95/98 and PCMCIA.
ATT: Do not use on Aston 1.04 CAM only on 1.00 or 1.03 versions.
Perfrom this at your own risk.. I had no problems, but it could fry your cam...
Files:
load.exe Program to load .bin file to CAM
aston95.inf driver file for Aston CAM under win95
aston98.inf driver file for Aston CAM under win98
cryptoworks95.inf driver file for Cryptoworks CAM under win95
cryptoworks98.inf driver file for Cryptoworks CAM under win98
aston103.bin Aston CAM v1.03 update file
cw112.bin Cryptoworks CAM v1.12 update file
cw114.bin Cryptoworks CAM v1.14 update file
UpgradeReadme.txt This file
Delete the .inf files you don't need, for example leave aston98.inf if using win98 and updating an aston Cam.
Boot your PC into windows insert your cam and when prompted for the driver point it to the directory
with the .inf file. If prompted to restart do so.
Ensure that in device manager you have a Smart Card section with the CAM with no error symbols.
If you have errors you may need to adjust the resource settings.
Only proceed if you are sure of the above.
Run a command prompt change (MS-DOS Prompt) to the temp directory and enter below on one line.
load aston103.bin (for update to aston 1.03)
or
load cw114.bin (for update to Cryptoworks CAM v1.14)
and so on......
It should then cycle through a counter which is programming your cam.
Do not interupt it, breath too heavley etc when it is programming as this will fry your cam.
When it is finished it will tell you.. Press Q to quit.
You can remove your CAM and there you go you have a an updated CAM :-)
Hope this helps you..
Regards,
thanks to [Only registered and activated users can see links. Click Here To Register...]
si vezi poate te ajuta si asta [Only registered and activated users can see links. Click Here To Register...]
