VU+ Duo 4K Lite
VU+ Duo 4K Lite
Coming soon.
Linux UHD Set-Top-Box
Instructions
Datasheet
Software
Television as it should be: fast, flexible, uncompromising
The VU+ Duo 4K Lite expands VU+'s already extensive product range with another device. The VU+ Duo Lite offers space for two plug-and-play Full Band Capture (FBC) tuners, enabling lightning-fast channel switching. The built-in tuner slots accommodate two FBC tuner modules (DVB-S2, DVB-C) or DVB-T2 dual tuner. Ample CPU resources, Gigabit LAN, dual-band Wi-Fi, Bluetooth, and USB 3.0 and USB-C ports open up entirely new possibilities for the future.
High-performance 4K reception with an FBC tuner for simultaneous recording and live TV, state-of-the-art HEVC decoding, and the future-proof Enigma2 Linux platform make the DUO 4K Lite the top choice for TV enthusiasts. Record directly, pause live TV, stream media on your network, and use CI modules for encrypted channels – all in an elegant, energy-efficient design. Reliable, flexible, and expandable – ideal for private enjoyment or sophisticated home entertainment setups.
What is a DVB-S2 FBC Twin Tuner?
A DVB-S2 FBC twin tuner has 8 demodulators. With two conventional satellite feeds (e.g., a twin LNB), the tuner is comparable to 2 conventional tuners and 6 additional tuners operating in loop-through mode. This allows you to simultaneously watch, stream, or record channels from 8 different transponders across 2 different satellite bands. In SCR (Unicable) mode with 8 frequencies, this is equivalent to 8 conventional tuners.
What is a DVB-C FBC tuner?
A DVB-C FBC tuner has 8 demodulators. This is equivalent to a receiver with 8 conventional DVB-C tuners. You can therefore watch, stream, or record 8 channels simultaneously.
What is a DVB-T2 dual tuner?
A DVB-T2 dual tuner has two demodulators and allows simultaneous
Watch, stream or record 2 programs.
Key features
Very fast switching times
WebKit Browser
Chromium OS
Transcoding
HbbTV
HDMI 2.0 output
HDMI 2.0 input
Gigabit LAN
Dual-band WiFi (2.4 / 5 GHz)
Simultaneous decryption of 2 CI modules
BT 5.4 for e.g. BT soundbars or headphones
3.0" TFT LCD Display - Mini TV
2x tuner slots for e.g. DVB-S2X / DVB-C* Full Band Capture (FBC) or DVB-T2 Dual Tuner
2 x USB 3.0
1.7 GHz Dual Core CPU
eMMC flash memory
HEVC / H.265 video decoding
Plug & Play removable drive bays for 2.5" SATA hard drives (max. 15 mm HDD height)
External 12V power supply
Scope of delivery
1x VU+ Duo 4K lite with selected tuner configuration
1x remote control
1x Quick Manual (German / English)
1x HDMI cable
2x AA batteries
1x power supply (110-240V / 12V)
Coming soon to German shops... Approximate price €339 without tuners and €419 with two tuners.
thx to:maumixio
