OpenSPA images for sat receivers HD/4K
here you can find firmware for the following receivers:
AB-pulse
AX
Amiko
DINOBOT
Edision
Ferguson
Formuler
Galaxy Innovations
GigaBlue
HITUBE
IZIBOX
James Donkey
Maxtech
Mutant
Octagon
Qviart
Uclan Ustym
Vu+
Zgemma
OpenSPA 8.6.001
What is new
- New drivers:
VU+.
update drives for DVB-T2 tuners with BCM3466-P10 chipset
- Update to OE-A 5.6 based on OpenEmbedded OE5.2 and OE5.3 (walnascar and whinlatter).
- Python 3.13.11 with improvements such as:
Performance improvements thanks to an optimized interpreter architecture.
Reduced memory consumption and more stable management while simultaneously increasing speed.
Improved compatibility with modern CPUs, including optimizations for ARM.
Enhanced security through encryption updates and integration with OpenSSL.
- OpenSSL 3.6.0
- FFmpeg 8.0
- Kodi updated to 22.0 alpha2.
- Updated Tailscale to 1.92.3 (remember that it can also be updated from the plugin)
- Updated rclone to 1.71.1
- Updated gstreamer to 1.26.9
- Updated Samba to 4.23.1
- Updated sabnzbd to 4.5.5
- Updated exteplayer3 to 181
- Updated Wi-Fi drivers for rtl8192eu on Linux kernel 4.10.x
- Updated Transmission startup script.
- Update PanelExtra
Picons section. Add pelajustrana picons, fix jungle_team picons download and optimize code.
OnlineTV section. Fix iptv.org channels download and optimize code.
- New Boot logo, thanks to @ elduque
- OSCamInfo: Added the capabilities of the OSCam binary to the YELLOW button (equivalent to "Files" in OSCamWebif).
- CAMD Manager:
Fixed spinner when stopping, starting, or restarting.
Fixed error when accessing from the BLUE "Download" button when there is no Internet connection.
- Photos/Images: Added support for Webp files developed by Google.
- Information (Memory and Tuning):
Improved information on RAM distribution in the system.
Displays DVB-S Symbol Rate and frequency values with division.
- TimeShift:
Added the option to set a time delay in the TimeShift settings to recover from streaming after an error.
TimeShift file buffer controllers have been added.
The issue of the InfoBarTimeshift displaying when the OK button is pressed has been resolved.
The ability to save TimeShift using the STOP key has been added.
A "Timeshift Active" warning screen has been added to the InfoBarTimeshift display when PAUSE, PLAY, or STOP is enabled, with "Automatically start timeshift after" enabled. This warning screen indicates whether Timeshift is active. If "Automatically start timeshift after" is enabled, it will remain active even after pressing STOP. Pressing STOP will display "Timeshift Active," providing information that temporary files are being created on the device. Currently only available on the default OpenStarHD skin. Thanks to @ danyyy for the reports.
- FlashManager (Flash Online):
Image download counter added.
Fixed downloading only the image (BLUE button).
- Wizard: Added wizard step counter.
- DVB: Fixed signal for the "Vuplus DVB-T NIM(BCM3466)" VU+ Dual DVB-T2 tuner.
- Navigation:
Fixed spinner loop when using FBC tuners in channel surfing with FCC and the backup tuner active.
This may resolve some loops when surfing IPTV with these tuners; it has been achieved in IPToSAT.
- Add-ons: Fixed underlying issues in this new GUI code.
- Fallback Tuner: Fixed EPG cache download from various paths on the backup receiver (internal or external devices).
- Hotkeys:
Enabled the "Configure Keys" menu for Enigma. Menu > Settings > Usage and Interface > Configure Keys
If the spaQButton plugin is installed, this menu will open the program to configure the keys.
If spaQButton is used, the keys previously assigned in Enigma's "Configure Keys" will be automatically deactivated.
- spaQButton (Remap Keys): Added scanning functions, Video Enhancement Settings, Engine Settings, Help Menu, Language Selection, Skin Selection, and Network Services. Suggested by @ danyyy
-IPToSAT:
Fixed a loop when channel surfing on the reserve tuner with FBC receivers and FCC functionality.
Added the ability to restore only the channel list from the backup.
- IPTVChannels: Code improvements.
User : root
Pass : openspa
