Buna
C-am ce comenzi mai exista (in afara celor interne din dream ,afisate cu help) ?
Presupun ca exista si alte comenzi utile (gen reboot).
Multumesc
Buna
Multumesc
google < busybox>
Intradevar , foarte multe comenzi.
Se pot schimba canalele la DM500 din telnet ?
Absolut nu.Quote:
Originally Posted by delta2k2 [Only registered and activated users can see links. Click Here To Register...]
Show me who is online, which IP and which Gbox Version is running:
# cat /var/tmp/share.onl
Show me all Distance 1 cards:
# grep "dist:1" /var/tmp/share.info
Show me all Distance 1 cards and resolve the Provider ID:
# for i in `grep 'dist:1' /var/tmp/share.info | awk '{print $6}' | sort` ; do grep "^$i" /var/keys/ident.info ; done
With this command, you can also see if gbox process is running:
ps -ef
To see number of cards from a peer
cd /tmp/ grep <peer domain> share.info | wc -l
To see cards from a peer with distance and level
To see peer status
cd /tmp/ more share.onl
To see number of cards with level X where X = number
cd /tmp/ grep Lev:X share.info | wc -l
To see number of cards with level X for a certain peer where X = number
cd /tmp/ grep <peer domain> share.info | grep Lev:X | wc -l
To see number of cards at distance X where X = number
cd /tmp/ grep dist:X share.info | wc -l
To see number of cards with distance X for a certain peer where X = number
cd /tmp/ grep <peer domain> share.info | grep dist:X | wc -l
Mi s-a intamplat uneori sa mi se blocheze dream-ul (testand unele skin-uri).
Singura solutie ...cablu null modem...imagine noua.
Din telnet exista vre-o comanda care sa reseteze skin-ul (la cel de baza) ?
Dar un factory reset se poate ?
Multumesc.
am patit si eu asa, am reusit insa sa ma conectez cu dcc la el, am sters tot ce era din skinul nou, tastat in telnet reboot si a intrat pe cel standart
Desi am reusit telnet cu reboot ...la mine nu a vrut.Quote:
Originally Posted by snow [Only registered and activated users can see links. Click Here To Register...]
Poate depinde de imagine ...(cred ca nu e asa greu sa pui un IF acolo ...daca nu exista fisierele noului skin THEN ...standard skin)
eu am patit pe nemesis. ca sa eviti problemele, salveaza varul functional, iar daca se intampla sa ai probleme, il pui si reboot
un site interesant [Only registered and activated users can see links. Click Here To Register...]
gasiti inclusiv comenzi pentru telnet
Dap, [Only registered and activated users can see links. Click Here To Register...]. Foarte bun linkul.Quote:
