sid limitare la focus?
Salut
Incepand de luna asta cardul de focus face fite, daca cere un nr mai mare de ecm-uri pe diferite siduri cardul se blocheaza si trebuie restartat:
- 2016/11/12 04:23:51 3101512E c (ecm) digitvoscam (0B02@000000/0000/7736/4E:0A308D05FE87FFBF7E6FE7C1BC0296FB): found (258 ms) by focus
- 2016/11/12 04:24:22 3101512E c (ecm) digitvoscam (0B02@000000/0000/7812/84:9697C80E113F995084FBF14FEDF97F6E): found (328 ms) by focus
- 2016/11/12 04:24:24 3101512E c (ecm) digitvoscam (0B02@000000/0000/7812/84:2E2DE8671DF4AA54691CE3EAC8A96C16): found (328 ms) by focus
- 2016/11/12 04:24:28 3101512E c (ecm) digitvoscam (0B02@000000/0000/7725/97:6AF7A429EAE0CAFFE5DBCFEBA114C947): found (389 ms) by focus - Nat Geo Wild Romania HD
- 2016/11/12 04:24:38 3101512E c (ecm) digitvoscam (0B02@000000/0000/7725/97:675E41F958F66706ED458D055FD9911F): found (391 ms) by focus - Nat Geo Wild Romania HD
- 2016/11/12 04:24:48 3101512E c (ecm) digitvoscam (0B02@000000/0000/7725/97:34D2B940BAAE9F9D6CF131877D8FA630): found (389 ms) by focus - Nat Geo Wild Romania HD
- 2016/11/12 04:24:48 3101512E c (ecm) digitvoscam (0B02@000000/0000/7596/A9:3D6369AF39AEC5C0B0D5E210D555DEED): found (411 ms) by focus - Hir TV
- 2016/11/12 04:24:52 3101512E c (ecm) digitvoscam (0B02@000000/0000/7596/A9:870595D5A1973FBA9E3877BD23BA254F): found (412 ms) by focus - Hir TV
- 2016/11/12 04:24:58 3101512E c (ecm) digitvoscam (0B02@000000/0000/7725/97:5D3A9481F03F433BF9F7FEF3152D60CE): found (390 ms) by focus - Nat Geo Wild Romania HD
- 2016/11/12 04:25:08 3101512E c (ecm) digitvoscam (0B02@000000/0000/7725/97:60346CB7187C86C3ADAAA22DCF7EA14D): found (390 ms) by focus - Nat Geo Wild Romania HD
- 2016/11/12 04:25:11 72119369 r (reader) focus [conax] card has no right to decode this channel
apoi da not found pe toate canalele.
Cardul trebuie restartat apoi merge un timp f scurt
A mai intampinat cineva problema asta?
Eu zic sa controlezi config inaite.
L-am controlat. Folosesc oscam ptr a citi cardul de focus,.Ai card de focus?
Ce PIN folosesti in oscam.config ?
Nu am nici un cod pin in oscam.config. Ce ar trebui sa pun la pin code?
1234 ! Este pin cod de la cardul focus. In principiu fara asta nu se deschid pornografiile. Nu cred ca eroarea ta are legatura cu cod pin. Mai degraba cu frecventa cardului. Joaca-te pe acolo, pleaca de la frecv default sau lasa necomplectate campurile alea sa vezi ce alege oscamul tau. Spor !
Salut prieteni,
Am gasit buba, cardul a fost pus intr-un readear in care a fost un card de digi cu bk si rsa puse, am uitat sa le sterg. In campurile respective pot fi puse si bk si rsa ptr conax, asa ca atunci cand, cardul primea un request pe un canal care nu era in subscriptie
cardul dadea eroarea focus [conax] card has no right to decode this channel. Am sters datele din bk si rsa si totul a revenit la normal, cardul de focus merge struna. Scuze ptr alarma falsa.
Merg eroticele si fara cod pin
"Merg eroticele si fara cod pin"....nu si la cel care vede de la tine.
