Dreamtv Mini Ultra HD
Dreamtv Mini Ultra HD the smalest and most powerfull Android STB
Main features DreamTV Mini Ultra HD media player
Android 9.0
Quad-Core Amlogic S905X2 Processor
Dual WIFI
2GB RAM
16GB Interval Speecher
4K resolution (60FPS)
The DreamTV Mini UltraHD media player from Dreambox is Android 9.0 based. This player has a powerfull 4 Core CPU and 2GB RAM. The DreamTV Mini UltraHD media player has a built-in WiFi 2.4G/5G MIMO connection and a 100 Mbit ethernet port. A SD card reader is also integrated in this media player. The DreamTV Mini Ultra HD set-top box gets its signal via internet, so a satellite antenna is not required!
4K Ultra-HD
The DreamTV Mini Ultra HD media player supports 4K Ultra-HD/HDR 10. To enjoy 4K image quality also a 4K TV needs to be connected! Within a few steps you can create your own Favourite lists, with your own favourite channels. With this DreamTV receiver you can set up multiple stream sources, and include 'live' and video-on-demand (VOD) channels to your own platform.
Applications & Games
This Dreamtv set-top box turns your TV into a SmartTV; via the Android interface all kind of APP's and games can be installed. The DreamTV Mini ultra HD IPTV receiver is based on the DreamTV App; this App is exclusively designed for this set-top box and assures an user-friendly control of the box.
Many connection options
The DreamtV Mini Ultra HD IPTV has lots of connection options for external devices. Next to a built-in Bluetooth 4.2 connection, also an optical connection is available for the best sound quality. Also the possibility to connect an external hard drive and / or USB stick is possible via the available USB 2.0 or USB 3.0 port. Updating of the box is easy via the available service port.
Technical parameters DreamTV Mini Ultra HD IPTV media player
Supported protocols / portals
M3U-lists
Stalker
Xstream Codes
Enigma 2
And more...
General
4k 60 FPS
CPU 4 core
Flash 16GB
GPU Mali-G31MP2
WiFi 2,4G/5G MIMO
H2.64/H2.65
HDMI
100Mbit Lan
Optical input
Mini USB Service Port
SD card reader
1x USB 3.0
1x USB 2.0
Bluetooth 4.2
Android 9.0
2GB RAM
Content packaging:
RC 20 remote control
Twee AAA batteries
Power adapter (12V)
HDMI cable
Slab la dotari,android 9 ,2gb ram....pierd din start
