Telnet Enigma2
Cateva comenzi utile pentru incepatori si nu numai..
PHP Code:
1- wget -q "--no-check-certificate" https://raw.githubusercontent.com/ziko-ZR1/Epg-plugin/master/Download/installer.sh -O - | /bin/sh
2- wget -q "--no-check-certificate" http://ipkinstall.ath.cx/ipk-install/E2IPLAYER-DREAMSATPANEL/e2iplayer.sh -O - | /bin/sh
3- wget -q "--no-check-certificate" https://raw.githubusercontent.com/ziko-ZR1/FootOnsat/main/Download/install.sh -O - | /bin/sh
4- wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/IPtoSAT/installer.sh -qO - | /bin/sh
5- wget -q "--no-check-certificate" http://linuxsat5.webhop.info/ipaudio/installer.sh -O - | /bin/sh
6- wget https://raw.githubusercontent.com/biko-73/AjPanel/main/installer.sh -O - | /bin/sh
7- wget https://raw.githubusercontent.com/biko-73/xstreamity/main/installer.sh -O - | /bin/sh
8- wget https://raw.githubusercontent.com/fairbird/RaedQuickSignal/main/installer.sh -O - | /bin/sh
9- wget -q "--no-check-certificate" http://ipkinstall.ath.cx/ipk-install/DreamSatPanel/installer.sh -O - | /bin/sh
@@ RestartEnigma @@
systemctl restart enigma2 # DreamOS
killall -9 enigma2 # Opensource
@@ openpli IP Audio @@
opkg install gstreamer1.0-plugins-good gstreamer1.0-plugins-base gstreamer1.0-plugins-bad-meta gstreamer1.0-plugins-ugly libgstplayer-1.0-0
opkg install --force-depends gstreamer1.0-plugins-bad-meta
@@ Delete Image @@
rm -R /etc/enigma2 && killall -9 enigma2
@@ Log Enigma2 @@
init 5; enigma2.sh >/tmp/enigma2_logfile.log 2>&1
@@ Log Enigma2 Dreamos @@
journalctl -f -u enigma2>/usr/enigma_log
@@ Debug Enigma @@
init 4; sleep 5; enigma2 >/tmp/enigma2_debug.log 2>&1
@@ Remove Log @@
find $HOME -name '*.log' -exec rm {} \;
@@ Init Codes @@
init 0 # Deep Standby
init 1 # Stops Enigma2 and network
init 3 # Starts Enigma2 normally
init 4 # Stops Enigma2
init 6 # Reboots the box
@@ Directory @@
pwd # Current Dir
cd # Home
cd .. # Up
cd / # Root
cd $HOME # Home
cd /tmp # /tmp
@@ File List @@
ls
ls --full-time
ls -1
ls -als
ls -ls
@@ Search @@
find / -iname FILE_NAME
find / -size +10000k
grep -r PATTERN dir
grep PATTERN FILES
@@ System @@
which FILE_NAME
echo root:XXXX | chpasswd # Change Password
date
top
uname -a
uptime
whoami
dmesg | more
shutdown -r now # Full reboot.
shutdown -h now # Full shutdown.
cat /proc/meminfo # memory info
@@ User @@
id
last
who
@@ Network @@
ifconfig
netstat
head -n 1 /etc/hostname # Show Hostname
ping google.com -c 3 # 3 seconds
ip route get 1.2.3.4 | awk '{print $7}' # Show IP addresses
hostname -i | awk '{print $1}' # Show locale host
@@ DNS Google @@
echo "nameserver 8.8.8.8" > /etc/resolv.conf; echo "nameserver 8.8.4.4" >> /etc/resolv.conf; killall -9 enigma2
@@ Change MAC @@
ifconfig eth0 down
ifconfig eth0 hw ether xx:xx:xx:xx:xx:xx
ifconfig eth0 up
ifconfig eth0 | grep HWaddr | awk '{print $5}'
echo $(ethtool -P eth0 | awk '{print $3}')
@@ File Permission @@
chmod 755 /tmp/FILE_NAME
chmod 766 /tmp/FILE_NAME
chmod 777 /tmp/FILE_NAME
@@ Disk usage @@
df -h
df -i
df -a
@@ Sound @@
alsamixer
@@ Delete Portals @@
init 4; sleep 5; sed -e s/config.plugins.MultiStalker.portals.*//g -i /etc/enigma2/settings; init 3
@@ Stalker Portals @@
wget -qO $HOME/stalker.conf https://raw.githubusercontent.com/karimSATPRO/Portal-100mag/main/stalker.conf; killall -9 enigma2
@@ Opensource @@
opkg update
opkg download FILE_NAME
opkg whatdepends FILE_NAME
opkg --autoremove FILE_NAME
opkg update; opkg upgrade
opkg flag hold FILE_NAME # Stop Plug-in auto updating
opkg flag user FILE_NAME # Star Plug-in auto updating
opkg install --force-overwrite /tmp/*.ipk
opkg install $(< packList.txt)
opkg remove $(< packList.txt)
opkg list | fgrep -i FILE_NAME
opkg remove --force-depends FILE_NAME
opkg remove --force-depends enigma2-plugin-softcams-ncam
opkg remove --force-depends enigma2-plugin-softcams-oscam*
@@ DreamOS @@
apt-get update
apt-get update; apt-get upgrade
apt-get install -f -y
dpkg -i --force-overwrite /tmp/*.deb
apt-get purge --auto-remove FILE_NAME
apt-get purge --auto-remove enigma2-plugin-softcams-ncam
apt-get purge --auto-remove enigma2-plugin-softcams-oscam*
@@ Python 2 @@
opkg install python-requests
opkg install python-sqlite3
opkg install python-beautifulsoup4
opkg install python-pycrypto
opkg install python-urllib3
@@ Python 3 @@
opkg install python3-requests
opkg install python3-sqlite3
opkg install python3-beautifulsoup4
opkg install python3-pycrypto
opkg install python3-urllib3
@@@@--- Command ---@@@@
opkg install nano
opkg install wget
opkg install curl
opkg install astra-sm
opkg install dvbsnoop
opkg install ffmpeg
opkg install enigma2-plugin-extensions-clearmem
opkg install enigma2-plugin-extensions-cacheflush
opkg install enigma2-plugin-extensions-chromium2
opkg install qtwebengine
opkg install enigma2-plugin-drivers-ntfs-3g
opkg install enigma2-plugin-drivers-exfat
opkg install gstplayer libgstplayer-1.0-0
opkg install exteplayer3
opkg install livestreamer
opkg install livestreamersrv
opkg install libusb-1.0-0
opkg install libssl1.0.2
opkg install libcurl4
opkg install libpcsclite1
opkg install libcrypto1.0.2
opkg install enigma2-plugin-systemplugins-serviceapp
opkg install --force-reinstall enigma2-plugin-systemplugins-serviceapp
opkg install gstreamer1.0-plugins-base
opkg install gstreamer1.0-plugins-bad
opkg install gstreamer1.0-plugins-ugly
opkg install gstreamer1.0-plugins-bad-meta
opkg install enigma2-plugin-systemplugins-softcamstartup # TeamBlue
opkg install enigma2-plugin-systemplugins-softwaremanager # Openpli 8.3
@@ Skins @@
opkg install enigma2-plugin-skins-metrix-atv-fhd-icons
opkg install enigma2-plugin-skins-madmax-impossible
opkg install enigma2-plugin-skins-pdreamy-fhd
@@ myflow_DreamOS @@
wget https://raw.githubusercontent.com/ostende/dreamos-skins/main/myflow/myflow-installer_dreamos.sh -qO - | /bin/sh
@@ Nitro AdvanceFHD @@
wget https://raw.githubusercontent.com/biko-73/NitroAdvanceFHD/main/installer.sh -qO - | /bin/sh
@@ Red-Dragon-FHD @@
wget https://raw.githubusercontent.com/biko-73/zelda77/main/installerR.sh -qO - | /bin/sh
wget https://raw.githubusercontent.com/biko-73/TeamNitro/main/script/installerD.sh -O - | /bin/sh
@@ Klll-Pro @@
wget https://raw.githubusercontent.com/biko-73/zelda77/main/installer.sh -qO - | /bin/sh
@@ Metrix-FHD @@
wget http://ipkinstall.ath.cx/ipk-install/MetrixFHD/MetrixFHD.sh -qO - | /bin/sh
@@ Novax-FHD @@
wget https://github.com/popking159/down/raw/master/novax-fhd-install.sh -qO - | /bin/sh
@@ BO-HlaLa FHD @@
wget https://raw.githubusercontent.com/biko-73/TeamNitro/main/script/installerB.sh -O - | /bin/sh
@@ SoftCam secret feed @@
wget http://updates.mynonpublic.com/oea/feed -qO - | /bin/sh
@@ Kodi : Opensource @@
opkg install enigma2-plugin-extensions-kodi
opkg remove --force-depends kodi
opkg install kodi-addon-pvr-iptvsimple kodi-addon-pvr-vuplus
@@ Wifi Driver @@
@@ Driver Wifi Novaler @@
opkg list-installed | grep mt7601u
opkg install enigma2-plugin-drivers-network-usb-mt7601u
opkg remove --force-depends enigma2-plugin-drivers-network-usb-mt7601u
@@ Driver Wifi 5370 @@
opkg list-installed | grep rt3070
opkg install rt3070 firmware-rt3070
@@@@--- Plugins ---@@@@
@@ e2script @@
python -c "$(wget https://raw.githubusercontent.com/MOHAMED19OS/e2script/main/e2script.py -qO -)"
@@ Bugs Bunny @@
sh -c "$(wget http://tropical.jungle-team.online/auto_install_images/Bugs_bunny_1.10.sh -qO -)"
@@ FreeServerCCcam @@
wget https://ia803104.us.archive.org/0/items/freecccamserver/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/FreeServer
@@ NovaIPAudio @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/NovaIPAudio/installer.py -qO - | python
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/NovalerIPaudio
@@ NovalerTV @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/NovalerTV/installer.py -qO - | python
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/NovalerTV
@@ NovCam @@
python -c "$(wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/NovCam/installer.py -qO -)"
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/NOVACAMSUPTVActivator
@@ PlutoTV @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/PlutoTV/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/PlutoTV
@@ Quran Karim @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/Quran/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/Quran
@@ AJPanel @@
wget https://raw.githubusercontent.com/biko-73/AjPanel/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/AJPan
@@ Arabic Savior @@
wget https://raw.githubusercontent.com/fairbird/ArabicSavior/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/ArabicSavior
@@ YouTube @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/YouTube/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/YouTube
@@ IPtoSAT @@
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/IPtoSAT
@@ FootOnsat @@
wget https://raw.githubusercontent.com/ziko-ZR1/FootOnsat/main/Download/install.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/FootOnSat
@@ IP Audio @@
wget http://ipkinstall.ath.cx/ipaudio/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/IPAudio
@@ E2iPlayer_TSIPlayer @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/E2IPLAYER_TSiplayer/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/IPTVPlayer
@@ Raed Quick Signal @@
wget https://raw.githubusercontent.com/fairbird/RaedQuickSignal/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/RaedQuickSignal
@@ EPG Grabber @@
wget https://raw.githubusercontent.com/ziko-ZR1/Epg-plugin/master/Download/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/EPGGrabber
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/EPGGrabber/api/epg_status.json
@@ Key Adder @@
wget https://raw.githubusercontent.com/fairbird/KeyAdder/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/KeyAdder
@@ SupTv @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/Suptv/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/suptv
@@ Multi-Stalker @@
wget https://raw.githubusercontent.com/ziko-ZR1/Multi-Stalker-install/main/Downloads/installer.sh -qO - | /bin/sh
wget -O /usr/lib/enigma2/python/Plugins/Extensions/MultiStalker/commons/commons.py https://raw.githubusercontent.com/karimSATPRO/Portal-100mag/main/commons.py && killall -9 enigma2
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/MultiStalker
@@ New Virtual KeyBoard @@
wget https://raw.githubusercontent.com/fairbird/NewVirtualKeyBoard/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/SystemPlugins/NewVirtualKeyBoard
rm -rf /usr/lib/enigma2/python/Screens/NewVirtualKeyBoard.py*
@@ Multiboot FlashOnline @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/FlashOnline/installer.py -qO - | python
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/FlashOnline
@@ Ansite @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/Ansite/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/Ansite
@@ XcPlugin Forever @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/XC-Code/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/XCplugin
@@ SubsSupport @@
wget https://raw.githubusercontent.com/biko-73/SubsSupport/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport
@@ DreamSatPanel @@
wget http://ipkinstall.ath.cx/ipk-install/DreamSatPanel/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/DreamSat
@@ XtraEvante @@
wget https://github.com/digiteng/xtra/raw/main/xtraEvent.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/xtraEvent
rm -rf /usr/lib/enigma2/python/Components/Converter/xtra*
rm -rf /usr/lib/enigma2/python/Components/Renderer/xtra*
rm -rf /usr/share/enigma2/xtra
@@ JediMakerXtream @@
wget https://raw.githubusercontent.com/biko-73/JediMakerXtream/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/JediMakerXtream
@@ X-Streamity @@
wget https://raw.githubusercontent.com/biko-73/xstreamity/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/XStreamity
@@ OpenMultiboot @@
wget https://raw.githubusercontent.com/biko-73/openmultiboot/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/OpenMultiboot
@@ OpenMultiboot Enhanced by e2TURK @@
wget https://raw.githubusercontent.com/e2TURK/omb-enhanced/main/install.sh -qO - | /bin/sh
@@ NEOBOOT @@
wget https://raw.githubusercontent.com/gutosie/neoboot/master/iNB.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/NeoBoot
@@ BackupFlash @@
wget https://raw.githubusercontent.com/fairbird/backupflash/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/backupflashe2
@@ NordVPN @@
wget http://nordvpnconnector.dd-dns.de/nvpnc-installer_ipk.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/NordVPNConnector
@@ ChocholousekPicons @@
wget https://github.com/s3n0/e2plugins/raw/master/ChocholousekPicons/online-setup -qO - | bash -s install
wget https://github.com/s3n0/e2plugins/raw/master/ChocholousekPicons/online-setup -qO - | bash -s uninstall
@@ EvgQuickSignal @@
wget https://raw.githubusercontent.com/biko-73/EvgQuickSignal/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/EvgQuickSignal
@@ TheWeather @@
wget https://raw.githubusercontent.com/biko-73/TheWeather/main/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/TheWeather
@@ HasBahCa @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/HasBahCa/installer.sh -qO - | /bin/sh
rm -rf /usr/lib/enigma2/python/Plugins/Extensions/HasBahCa
@@ Channel @@
wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/Channel/installer.py -qO - | python
@@ EMU Install @@
python -c "$(wget https://raw.githubusercontent.com/MOHAMED19OS/Download/main/Emu/installer.py -qO -)"
@@ SpeedTest @@
wget https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py -qO - | python
@@ Softcam @@
wget -qO /etc/tuxbox/config/SoftCam.Key https://raw.githubusercontent.com/MOHAMED19OS/SoftCam_Emu/main/Enigma2/SoftCam.Key
rm -rf /etc/tuxbox/config/SoftCam.Key
@@ Satellites @@
wget -qO /etc/tuxbox/satellites.xml https://raw.githubusercontent.com/oe-alliance/oe-alliance-tuxbox-common/master/src/satellites.xml
rm -rf /etc/tuxbox/satellites.xml
@@ PowerCAM @@
wget http://files.powercam.me/powercam-openpli-arm.sh -qO - | /bin/sh # ARM CPU
wget http://files.powercam.me/powercam-openpli-mipsel.sh -qO - | /bin/sh # MIPSEL CPU
wget http://files.powercam.me/powercam-openpli-mipsel_oe2.0.sh -qO - | /bin/sh # MIPSEL OE 2.0 CPU
wget http://files.powercam.me/powercam-openpli-sh4.sh -qO - | /bin/sh # SH4 CPU
wget http://files.powercam.me/powercam-openpli-arm_64.sh -qO - | /bin/sh # AARCH 64 CPU
@@ DreamArabia Feed @@
# DreamOS 2.5 #
apt update && wget -O /tmp/dreamarabia-addons-feed.deb http://dreambox4u.com/dreamarabia/2.5/DreamArabia-Addons/dreamarabia-addons-feed.deb && dpkg -i /tmp/dreamarabia-addons-feed.deb
# DreamOS 2.6 #
wget http://dreambox4u.com/dreamarabia/scripts/installer.sh -qO - | /bin/sh
@@ BoxPirates @@
wget http://boxpiratespanel.boxpirates.dynvpn.de/ipk-installer.sh -qO - | /bin/sh # Opensource
wget http://boxpiratespanel.boxpirates.dynvpn.de/dreamos-installer.sh -qO - | /bin/sh # DreamOS
@@ OpenWebif @@
wget http://tunisia-dreambox.info/TSplugins/openWebif/installer.sh -qO - | /bin/sh
@@ just watch @@
wget http://justwatch.boxpirates.dynvpn.de/dreamos-installer.sh -qO - | /bin/sh
@@ PlexDream @@
wget http://plugins.boxpirates.dynvpn.de/plexdream-dreamos-installer.sh -qO - | /bin/sh
@@ Disney+ @@
wget http://disneydream.boxpirates.dynvpn.de/dreamos-installer.sh -qO - | /bin/sh
@@ Amazon Prime @@
wget http://amazonprimedream.bpdl2.mine.nu/dreamos-installer.sh -qO - | /bin/sh
@@ DAZN Dream @@
wget http://dazndream.boxpirates.dynvpn.de/dreamos-installer.sh -qO - | /bin/sh
@@ Netflix Dream @@
wget http://netflixdream.boxpirates.dynvpn.de/dreamos-installer.sh -qO - | /bin/sh
@@ MediaPortal OE2.5 @@
wget http://feed.newnigma2.to/mpgz/mpgz-full-installer_dreamos_oe25.sh -qO - | /bin/sh
