Formuler S Mini 4K Android
- Main features :
- – Android 7.0
- – Satellite and IPTV in 4K UHD
- – HEVC H265 decoding
- – 4K UltraHD 10-bit 60fps
- – CPU / Chipset: Hisilicon chipset 1300 MHz
- – Flash 8Gb + 1 GBytes RAM (DDR4)
- – 1 x SAT Tuners
- – 1 x Card reader Slot
- – 2x USB 2.0 , 1x USB 3.0 and SD card slot (for Video file Playback & MP3 Player & JPEG Viewer)
- – Ethernet port
- Technical specifications :
- – Tuner & Channel Decoder (Satellite) :
- * Input Connector – F-type, IEC 169-24, Female
- * Frequency Range – 950MHz ~ 2150MHz
- * Signal Level – -65 to -25dBm
- * LNB Power – 13/18VDC, max.400mA
- * 22KHz Tone – (22±2)KHz, (0.6±0.2)V
- * DISEqC Control – V1.0/1.2/USALS Compatible
- * Demodulation – QPSK / 8PSK
- * Input Symbol Rate – 1 ~ 45 Ms/s (QPSK of DVB-S); 1 ~ 45 Ms/s (QPSK of DVB-S2)
- * FEC Decoder – 1/2,3/5, 2/3, 3/4, 4/5,5/6,8/9,9.10 and 7/8 (QPSK); 3/5, 2/3, 3/4, 5/6, 8/9 and 9/10 (8PSK)
- – A/V Decoding :
- * Video Decoding :
- – H.264/AVC BP/MP/HP@level 5.1, H.264/AVC MVC
- – H.265/HEVC Main/Main 10 profile@level 5.1 high-tier
- – AVS baseline profile@level 6.0, AVS-P16 (AVS+)
- – VC-1 SP@ML, MP@HL, AP@levels 0−3
- – Maximum 4K x 2K@60 fps 10-bit VP9 decoding
- * Input Rate – Max. 108Mbit/s
- * Video Formats – 4:3 Letter Box, 4:3 PanScan, 16 : 9
- * Video Resolution :
- – 720 x 576i, 720 x 480i, 1280 x 720p
- – 1920 x 1080i, 1920 x 1080p, 2160p(4K x 2K)
- * Audio Decoding :
- – MPEG-1 Layer 1,2
- – AAC-LC and HE AAC V1/V2 decoding
- * Audio Mode – Stereo/Joint Stereo/Mono
- * Sampling Rate – 8khz to 192khz sampling rate
- – Main System :
- * Main Processor – Hisilicon chipset
- * Memory :
- – eMMC : 8 GBytes
- – SDRAM : 1 GBytes (DDR4)
- – Audio / Video & Data IN/OUT :
- * TV OUT -Video & Audio Output
- * USB – USB3.0, USB2.0
- * Ethernet – RJ45 connector, 10/100M Base
- * Phone Jack – CVBS Video Output, Audio L, R Output
- * Micro SD Card – Micro SD Card Slot
- * IR Extension – Removable IR extension
- * S/PDIF – OPTIC
- – Front Panel :
- * Slot – 1 Smart Card Slot
- * Buttons – 1 Button (Standby)
- * Indicators – 1 Dual Color LED (Standby, Remote Control)
- – Power Supply :
- * Input Voltage – AC 100 ~ 240V, 50/60Hz
- * Type – Adaptor
- * Power Consumption – Max. 30W
- * Standby Power – Max. 0.5W (Ultra low power)
- * Protection – Separate Internal Fuse & Lightning protection
- – Box contents :
- * FORMULER S Mini
- * Premium Remote Control
- * Two AAA batteries (for the remote)
- * Power adapter
- * HDMI Cable
- * Quick Installation
