Amiko Mira3 Wifi
Amiko Mira3 Wifi
High Speed USB 2.0 Connection Support
6000 channels (TV and Radio) programmable
SCART support
External infra port
Built in WiFi
TimeShifting Support
Software Upgrade via USB
MKV, AVI, MPG, MP4, TS, VOB, JPEG & MP3
Playback Support
Dolby Digital Bit-Stream out via HD OUT
Low Power Consumption in Stand
MORE FEATURES
Timeshift support
Channel Recording & Timeshifting Simulteniously (optional)
Channel switching time less than 1 second
True-color, User Friendly On-Screen Display (OSD)
Full Picture In Graphic (PIG) function
Electronic Program Guide (EPG) for on screen channel information
Subtitle supported
Teletext supported by VBI insertion and software emulation
Parental lock facility by channel and program event
Program and Channel information transfer from receiver to receiver
Multi-Language support
Power Consumption in Stand-By: <0.5W
Tuner & Demodulation
Tuner Type: DVB-S / DVB-S2
Input Connector: F-type, Connector, Female
Signal Level: -65 to -25 dBm
LNB Power & Polarization: Vertical: +13V/+14V,
Horizontal: +18V/+19V
Current: Max. 400mA
Overload Protection
22KHz Tone Frequency: 22±1KHz
DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
Demodulation: QPSK, 8PSK
Input Symbol Rate: 2-45 Mbps,
FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
System Resources
Main Processor: Dual Core 650MHz
Flash Memory: 64MBits
DDR RAM: 1024Mbits
MPEG TS A/V Decoding
Transport Stream: MPEG-2, H.264
Input Rate: Max.120Mbit/s
Aspect Radio: 4:3, 16:9, Letter Box
Video Decoding: H.265/HEVC HD, MPEG-4/H.264 SP@L3 to ASP@L5, MP@ML, MP@HL, MP@4.1, HP@L4.1
Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p
Audio Decoding: MPEG-1/2,AAC-LC,HE-AAC,MP3,Dolby Digital plus
Audio Mode: Left / Right / Stereo/ Mono
Sampling Rate: 32, 44.1 and 48KHz
Power Supply
Input Voltage: 12V DC
Power Consumption: 18W Max
Stand-By Power Consumption: <0.5W
A/V & Data Input/Output
SCART: CVBS Video out / Audio L/R out
USB: One USB 2.0 slot
S/PDIF: Coaxial
Digital Video Output
IR Port: Internal & Jack Type
Physical Specifications
Net Weight: 0.25KG
Operation Temperature: 0°C~+45°C
Storage Temperature: -10°C~+70°C
Storage Humidity: 5%~95% RH (Non-Condensing)
