1-Stream / Xcode
1-Stream / Xcode
New code base, built according to modern standards
Utilizing the capabilities of ELK stack for system monitoring and activity logging
Ability to develop complex statistics and security features using the detailed logs in ELK without affecting system performance
Has API for 3rd party integrations and full management of API clients and restrictions
Distributed - full install on own servers with full control over them
Fast growing list of supported streaming devices and apps
Using newer technologies and best practices for software development
Improved security connections for end users, but backwards compatible with the old connection methods
Long list of planned features unique to the platform
Multiple player support, including own player
Stalker player for MAG devices
Legacy software code, hard to extend
Logging/monitoring performend in files/sql database makes it neccessary to keep data only for short period
Hard to integrate with 3rd party systems
Stopped developing
Base for many copies
Centralized ?? - installed on the provider servers
Using outdated methodologies
200 EUR/month Unlimited Load balancers FREE
1-Stream 1.1.21 Nulled
Before installation run the following or make sure to have mainserverip postgresqlsrv (e.g 12.12.12.12 postgresqlsrv) in /etc/hosts on every server.
or run the following: echo "mainserverip postgresqlsrv" >> /etc/hosts (e.g echo "12.12.12.12 postgresqlsrv" >> /etc/hosts
Be sure this is done BEFORE installation.
put onestream_all_v1.1.21.tar.gz in /home/onestream/iptv/
run bash /install_main.sh
when asked for APP_NAME, enter anything like 1-Stream
when asked for LICENCE, enter anything like 1stream-00000000000000000000
when installing load balancer, again put onestream_lb_v1.1.21.tar.gz in /home/onestream/iptv/
salutare .cine ma poate ajuta cu un link de unde pot descarca zip/file .cel afisat nu functioneaza ...multumesc
functioneaza înca... mai incearca...
nu pot descarca arhiva .te rog vrei sami lasi an privat ?
---------- Post added at 11:01 ---------- Previous post was at 10:59 ----------
la acele puncte nu stiu ce sa pun ?sal pot descarca .vrei sami lasi te rog linkul antreg ?multumesc
ce puncte?...trebuie sa dai numai click pe el..e linkul complet:
PHP Code:
https://www.mediafire.com/file/6dycpc7hb2128uu/onestream_v1.1.21.zip/file
L.E.: ...nu merge pus pe vps... trebuie dedicat!
salutare este picat ftp
dac ala este picat kitul de instalare este 0
practic nu al gaseste sal instaleze
404 Not Found [IP: 87.238.57.227 80]
ceva faci tu gresit... merge fara probleme...fii atent la: Before installation run the following or make sure to have mainserverip postgresqlsrv (e.g 12.12.12.12 postgresqlsrv) in /etc/hosts on every server.
