CK 43
➔ NEW: Fix several points to increase security against attacks and list scanner attempts.
➔ NEW: Implementation of version control internally in the source code.
➔ NEW: Optimization and sanitization of source code within DevSecOps standards.
➔ NEW: Improvements to overall system performance.
➔ FIXED: config.py corrupted after loadbalancer full remake.
➔ NEW...
✔ Update 44: 02 MARCH 2023.
➔ FIXED: 2 Auto ISP detect api (with contribution from Zoran api1 and Defeat api 2).
➔ NEW: Auto block bad user agents, sql injections, xss and many more security configs. (NGINX.CONF.SEC), in first use you need open this file and change the ports by yours and after rename as NGINX.CONF and restart service.
➔ FIXED: MAG522 in settings.
➔ NEW: New stream mass edit (with the contribution of jose)
➔ NEW: admin and wwwdir .htaccess with many rules against scanners and attacks.
➔ NEW: Block TCP IN from ALL china and Tor IP ranges.
➔ NEW: Block TCP IN from many hackers web proxies.
➔ NEW: Auto block more regex strings used by scanners.
---------- Post added at 00:15 ---------- Previous post was at 00:13 ----------
Update
---------- Post added at 00:34 ---------- Previous post was at 00:15 ----------
