DVB-T2/C tuner (HEVC/H.265 l AVC/H.264)
[Only registered and activated users can see links. Click Here To Register...]View Technical specification
- Fully compatible with DVB-T2/C digital standard
- Fully compatible with HEVC H.265/H.264/MPEG-4/AVS High Definition Digital TV
- Fully compatible with MPEG-2 High Definition and Standard Definition Output
- Fully compatible with MPEG-1/2 Layer I/II/III
- IR eye can be purchased separately
- 1 x Card Reader
- VHF&UHF Signal input
- On Screen Electronic Program Guide(EPG)
- Supports Auto search and Manual search
- Parental control for channels
- Plug and Play installation with an easy to use Menu System
- Supports 480p, 576p, 720p, 1080i/p Video Resolution
- Supports 4:3 and 16:9 Aspect Ratio
- DVB or EBU subtitle selected by the system based on availability on the network
- Various channel editing function(Favorites, Move, Lock, Delete)
- Support HDMI High Definition Multimedia Interface
- Software upgrade via USB2.0 interface
- USB 2.0 interface PVR and media player
- Record digital television program to an external USB portable hard disk and playback via USB2.0
DVB-T2 Tuner
System Resources
InputFrequency Range VHF&UHF Demodulation COFDM(QPSK/QAM16/QAM64)
Supports all five QAM modes:
16/32/64/128QAM, and 256 QAMBandwidth Bandwidth 7,8
Video Decoder
SDRAM memory 64 MB DDR2 SDRAM FLASH memory 4 MB FLASH
Audio Decoder
Standard ISO/IEC 13818-2 and ISO/IEC 14496-10 Transport stream ISO/IEC 13818-1 Video decoding HEVC H265/MPEG-2 SD/HD (MP@HL),
MPEG-4 H.264/AVS SD/HD JPEG,BMP,PNG,
Motion JPEG, AVI, VOB, MOV, MKVVideo Resolution 480p, 576p, 720p, 1080i, 1080p Aspect ratio 4:3, 16:9,Auto
Front Panel
Standard MPEG-1/2 Layer I/II/III,
MPEG-2/4 LC-AAC,
MPEG-4 HE-AAC@Level 4Sample rate 32, 44.1, 48 Subtitle DVB Subtitle
Rear Panel
Display Red / Green to indicate the various states of the STB Buttons On/Off, Ch+, Ch-
Left Panel
HDMI Digital HDTV video output with HDCP(optional). HDMI version 1.4 Antennal Input IEC169-2 Female Loop Output NO Scart port 1pcs SPDIF port 1pcs
Right Panel
Card Reader 1x
Accesioriess
IR port(mini usb Reader IR External LED Display USB 1xUSB2.0 interface
Power
Remote control User Manual
DC input range 5V,1A Power consumption Max 5W Operating Temperature 0 ~ 45 °C
adresa oficiala
user manual en
sw support
pret slovacia
16,50 €
