Scanare FocusSat - DM800SE
Salutare,
Incerc de cateva ore bune sa scanez canalele pe Focus Sat pe un DM800SE.
Acesta este fisierul meu satelittes.xml:
<sat name="0.8W Ku-band Thor 5/6/7 & Intelsat 10-02" flags="1" position="-8"> <transponder frequency="11688000" symbol_rate="1110000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11727000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11747000" symbol_rate="28000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11766000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11785000" symbol_rate="28000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11804000" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11823000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
<transponder frequency="11843000" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11862000" symbol_rate="28000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11900000" symbol_rate="28000000" polarization="0" fec_inner="4" system="0" modulation="1" />
<transponder frequency="11919000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11938000" symbol_rate="28000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11958000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="11977000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11996000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12015000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12034000" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12054000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12073000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12092000" symbol_rate="28000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12111000" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12130000" symbol_rate="28000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12149000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12169000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12188000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12207000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12226000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
<transponder frequency="12245000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12265000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12284000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12303000" symbol_rate="27500000" polarization="1" fec_inner="4" system="1" modulation="2" />
<transponder frequency="12322000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12360000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12380000" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12399000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12418000" symbol_rate="28000000" polarization="1" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12437000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12476000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" />
<transponder frequency="12527000" symbol_rate="28800000" polarization="0" fec_inner="7" system="1" modulation="1" />
<transponder frequency="12607000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12643000" symbol_rate="30000000" polarization="0" fec_inner="5" system="0" modulation="1" />
<transponder frequency="12643000" symbol_rate="28800000" polarization="1" fec_inner="3" system="1" modulation="2" />
<transponder frequency="12687000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
<transponder frequency="12687000" symbol_rate="28800000" polarization="1" fec_inner="7" system="1" modulation="1" />
<transponder frequency="12723000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
</sat>
Insa nu gaseste niciun canal.
Ce pot face?
Multumesc!
