Receptor Combo Uclan Ustym 4K Pro (Octagon SF8008 4H UHD)
Produs: Nou(Are 2 luni de cind a fost cumparat, testat o saptamana si pus in cutie)
Descriere: Receptor Combo Satelit+Cablu
Accesorii: toate
Pret: 100 Euro+ Transport
Garantie: Nu
Alte detalii: in PM
Schimb cu: bani
Contact:PM
Specificatii:
Multimedia, multifunctional TV combine! Terrestrial TV (DVB-T2), cable, satellite (digital and analogue), Internet video and audio sources in one small box!
SET-TOP BOX Uclan Ustym 4K PRO
The heart of 4K PRO is a modern and efficient processor Hisilicon Hi3798MV200 from Huawei. Thanks to this, 4K PRO mouth has high performance and the ability to switch channels instantly.
Ustym 4K PRO has a software based on Enigma 2 Linux, which provides a wide range of possibilities to use a large number of plugins, picoons, widgets and skins and allows you to customize the receiver to your needs.
Key features:
Enigma2 Linux OS operating system
DVB-S2X 4K UHD reception
PIP HD and UHD function (picture-in-picture)
Search for BlindScan channels
Support for Kodi applications
HbbbTV
Media playback: 2160P H.264 and H.265
PVR recordings (when an external drive or MicroSD is connected)
USB 3.0 port
Current consumption 0.5W (stand-by)
Small dimensions: (DxSxW) 220 mm x 125 mm x 40 mm
Characteristics:
Processor Hisilicon Hi3798MV200 Huawei
Quad Core 64Bit (4x 1.6 GHz) 15 000 DMIPS
RAM memory 1 GB DDR4
eMMC flash memory 8 GB
LAN 1GB Gigabit Ethernet (1000 Mbps)
Built-in 300 Mbps WiFi module, 2x WiFi antennas
7-segment display
Conax card reader with full OSCAM
DVB-S2X head
DVB-C/T2 head
HDMI 2.0
USB 3.0
MicroSD card slot
Front panel:
Infrared sensor (infrared receiver)
4-digit 7-segment display
On/off button with LED backlight (blue/red)
Right side panel:
USB 3.0 port
Card reader (CA CARD)
Back panel:
WiFi: 2x WiFi antennas
LNB input of DVB-S2X tuner
Input for H.265 HD DVB-C / T2
Dolby S-PDIF
AV – Audio Video Jack – Jack to RCA
RS-232 socket (maintenance and service)
HDMI 2.0a output
USB 2.0 port
MicroSD slot
Recovery button
DC-12V power supply
Power on/off switch
Contents of the set:
Receiver Uclan Ustym 4K PRO
Remote control (without batteries)
12V power supply unit
La cerere se pot aduce mai multe bucati
