Tivu Stream Plugin by Lululla
@ Lululla wrote:
Hello everyone
we are pleased to present an E2 plugin TiVu Stream that installs the channel lists:
iptv with about 3000 streams currently
Thanks to the BandbSat forum that made the server available
and to the work done by @buio2005 for this.
Soon there will also be a version for Android (apk) and Kodi & Kodilite
Still in the testing phase but I think the best way to know is to test it.
Very simple to use and also very light
Password for XXX channel download:
put in config : 1306
-tivustream.tar put in /tmp and command console telnet: tar -xvf /tmp/tivustream.tar -C /
-enigma2-plugin-extensions-tivustream_1.0_all.ipk : put in /tmp and command console telnet : opkg install --force-overwrite /tmp/*.ipk
-enigma2-plugin-extensions-tivustream_1.0_all.deb : put in /tmp and command console telnet : dpkg -i /tmp/enigma2-plugin-extensions-tivustream_1.0_all.deb
Reboot gui
Ps.:
unfortunately the Free IPTV Pandasat plugin will not be updated anymore nor the lists of that plugin.
So we decided to make a new lugin on a more stable server.
enigma2-plugin-extensions-tivustream_1.0_all.ipk.rar
Código:
enigma2-plugin-extensions-tivustream_1.0_all.deb.rar
Código:
tivustream.tar.zip
Código:
Update: V.1.2
-added in the config the possibility to choose a second server from where to download
-Select CORVONE in config and everything works
-Until we solve a problem in the central server
enigma2-plugin-extensions-tivustream_1.2_all.ipk.zip
Código:
