1 Attachment(s)
Freesat GTC 4K DVB-S2 DVB-C DVB-T2 ISDB-T
Freesat GTC DVB-S2 DVB-C DVB-T2 ISDB-T Amlogic S905D android 6.0 TV BOX 2 GB RAM 16 GB ROM BT4.0 Satellite Receiver
Amlogic S905D
Powered by an Amlogic S905D 64-bit quad-core ARM Cortex-A53 CPU, it is runs at up to 1.5GHz. On the graphics front, Freesat GTC sports an Penta Mali-450 for vivid and clear image display.
DDR4 2GB RAM, eMMC 16GB Flash
It boasts DDR4 2GB RAM, and eMMC 16GB Flash, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
Tuner specifications:
DVB-S2 DVB-S2 system standard:ETS 302 307
Symbol Rates: QPSK,8PSK
Forward error correction rate 1/4,1/3,2/5,3/5,2/3,3/4,4/5,5/6,8/9,9/10
Carrier frequency acquisition range: ±5MHz for symbol rates above 3 Msps and ±3MHz for the remaining symbol rates
Roll-off factors for pulse shaping: 0.2, 0.25 and 0.35
Symbol Rates: 1- 55 Msps
Code Rates: 1/2, 2/3, 3/4, 5/6, 7/8
Input Signal level: -84 dBm to 0 dBm (average power)
ANT. Connector:IEC TYPE F
DVB-T2 DVB-T2 system standard:ETSIEN 302 755
Support MPLP
Demodulation: QPSK,16QAM,64QAM or 256QAM
Forward error correction rate 1/2,2/3,3/4,3/5,5/6
Guard interval :1/4,19/256,1/8,19/128,1/16,1/32,1/128
Bandwith: 6/7/8MHz
Input Frange range:54--860MHz Input Impedance:75 Ω
ANT. Connector:IEC TYPE, female
DVB-C IEC 169-24 female 75Ω for input
Demodulation: 16QAM,32QAM,64QAM,128QAM,256QAM
Input Frange range:50--860MHz Input Impedance:75 Ω
ISDBT ISDB-T broadcast (1, 3, 13 segment),MPEG-2/MPEG-4 AVC/H.264 HD/SD Video , DiVX
FFT Mode: 2K/ 8K/32K
Demodulation: QPSK / 16QAM / 64QAM/QPSK or DQPSK
Forward error correction rate 1/ 2, 2/3, 3/4, 5/6, 7/8 Automatic
Guard interval : 1/4,1/8,1/16,1/32
Bandwith: 6/7/8MHz
Input Frange range:VHF:177.143~213.143 MHz:UHF 473.143~803.143MHz
Input Signal level: -83 dBm to 0 dBm (average power)
