Black Hole 3.0.5.A Quad PiP Vu+ Zero 4K Image
What is new ?
Update drivers(4k models)
- Fix demux problem
[bluetoothsetup/util] update for solo4k.
[vuplus-blindscan-utils] update TT2L08/TT3L10
[Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
- Fix HDR/HLG problem
- Fix grab problem
- Fix demux problem
- Improve overall performance
- Update kernel config
- Adjust driver memory allocations
update kodiegl/chromium/directfb.
[libdvbsi++] update to 0.3.8
[dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
update driver(zero4k)
- Fix DVB-CI problem
- Fix PLS
- Improve demux
This is available as an online update from 3.0.5 or as a full flash update.
Black Hole 3.0.5.E Quad PiP Vu+ Zero 4K Image
Black Hole 3.0.5.E
What is new ?
update drivers(uno4k, uno4kse, ultimo4k)
- Fix DiSEqC timing
- Support Dual DVB-S2X FBC tuner(needs E2 update)
update drivers(solo4k, uno4k, uno4kse)
- Fix media playback(24Fps)
Fix default recording path and usb recording.
[dvbapp] update.
[autofs] remove sync option for broken recording issue for ext4 filesystem.
[udev] fix automount.
Satdreamgr-6.0 Vu+ Zero 4K Image
The latest BlackHole image is 3.1.0 Multistream Vu+ Zero 4K Image
BlackHole-3.1.0-vuzero4k_usb_release_20201005_b5f1952.zip
