MpegTV A fast, standalone and lightweight mpegts proxy server
- Unlimited Channels, Streams, Movies, Users ,Servers and load balancers
- Very Fast client connection and fast zapping time
- No Third party software: no PHP, no NGINX, no FFMPEG
- Very low cpu and memory consumption
- Optimized stream connector/reader (you will never worry about vps server or cpu cores, only bandwidth matters)
- Smart stream selection by best video quality and stream stability
- Detect and block streams with video replay
- Auto Load-balancing by server bandwidth
- Highly optimised database that can handle more than 1000 clients so easily (NO FREEZE AND NO HIGH CPU LOAD)
- No Bandwidth Clipping from simultaneous multi connections
- Auto detect and block connected clients with different IPs
- MAG Devices Support (API portal.php)
- Xtream-Codes API: get.php, panel_api.php, enigma2.php, xmltv.php
- Supported Protocols (Input: MpegTS, UDP, HLS)+(Output: MpegTS)
- NEW (2017-09-01)
- Fixed connection master/slave
- Added EPG and Playlist data
- Fixed Reseller credit module for unlimited subresellers level
- Added reseller/subreseller credit log
Code:
http://www.infosat.org/
