OptiboX 7710 HD CICX
[Only registered and activated users can see links. Click Here To Register...] General data:
Pocket for 2 CI access modules
1 Smart Card Interface with Conax Embedded
VFD (Vacuum Fluorescent Display)
6000 Channels Memory
Electronic Program Guide (EPG) for OSD Channel information
Auto search & Manual search function
Easy Graphic MENU Interface
HDMI (High Definition Multimedia Interface) supported
Many OSD languages
3 Operation Modes (Digital TV, Digital Radio, Favorite)
Parental Lock function
Memory for multiple satellite management (up to 64)
Teletext Supported Through VBI & OSD
Last Channel Memory
Input Voltage Rang e: 90~240V AC 50/60 Hz
Power consumption: max 45 W
Operating Temperature: 0°C ~40 ° C
Size (WxHxD) in mm: 340x60x245
Net-Weight: 2,5 kg
Tuner:
Input Frequency Range: 950~2150 MHz
RF Input Level:-25~-65 dBm
LNB Power: 13/18 V DC (+(- 5%)
Max. 500 mA,
22kHz Tones: 22+/-4kHz, 0.6 +/- 0.2Vpp
Video Decoder:
Profile level:
- MPEG-4 part10 (H264) Level4
- MPEG-2 MP@ML; MP@HL
Video Resolution: 1080i; 720p; 576p; 576i(PAL)
Aspect Ratio: 4:3, 16:9(Letter Box)
Demodulation:
Modulation: QPSK; 8PSK
Input Symbol Rate: DVB-S: 2~45Ms/s
DVB-S2: 10~30Ms/s (QPSK); 10~30Ms/s (8PSK)
System and Memory:
Processor: STi7100
Flash Memory: 8Mbyte
System Memory: 64 Mbyte DDR-SDRAM
Video Memory: 64 Mbyte DDR-SDRAM
EEPROM: 16 kbyte
Audio Decoder:
MPEG/MusiCam Layer I & II,
Sampling rate: 32,44.1 & 48KHz
Audio modes: Mono/Dual Mono/Joint Stereo/Stereo
Connectors:
HDMI
SAT IN
SAT OUT
2 SCART TV (RGB, CVBS)/ VCR(RGB, CVBS)
RCA/Composite Video(CVBS)/Audio Left & Audio Right
S/PDIF(Optical)
RS232:9 way D RS232 DCE serial port
In Stoc - Pret - 850 Lei
