Ultimate IPTV - kodi addon
Ultimate IPTV is an addon that scrapes a blog for IPTV m3u8 lists.
The blog is daily updated with new lists. If a stream doesn't work, try another one.
The default playback mode is F4mProxy.
In the addon settings, you can change it to 'Direct', so it doesn't use F4mProxy.
Searching every list for the streams you need can be annoying with for example 1800 streams.
So in the addon settings you can set a filter. Like if you're looking for romanian streams, set it to 'ro'.
Or if you want all Sky channels, set it to 'sky'. It's case insensitive.
Installation instructions for Ultimate IPTV:
***If you already have Fusion installed skip to step #5***
- Select from the submenu under SYSTEM, FILE MANAGER
- Double click on ADD SOURCE
- Enter [Only registered and activated users can see links. Click Here To Register...] and click DONE
- Enter the name Fusion and click on OK
- Go to HOME and select SYSTEM
- Select ADDONS
- Select INSTALL FROM ZIP
- Select the red icon labeled Fusion
- Select xbmc-repos
- Select xxx-adult
- Select repository.whitecream-2.0.*.zip *latest version
- Wait until KODI refreshes all the repositories and
- Select install from repository
- Select WhiteCream repo
- Select Video Add-ons
- Select Ultimate IPTV
- Select INSTALL
- You now have successfully installed the Ultimate IPTV add-on on your KODI system!
- You can find it in Video -> Addons -> Ultimate IPTV
