Tivusat, ma ajuta cineva?
Card Tivusat 183d, pus in doua receptoare (Vu+ Solo2, intern sau smargo sau DM500+ intern), incercate cateva versiuni de oscam, aceeasi problema
Code:
1970/01/01 02:32:22 10121720 r bla [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=3.68 MHz1970/01/01 02:32:23 10121720 r bla [internal] card detected
1970/01/01 02:32:24 10121720 r bla [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
1970/01/01 02:32:24 10121720 r bla [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 02:32:24 10121720 r bla [internal] TEST tempo mhz check = 500 mhz
1970/01/01 02:32:24 10121720 r bla [internal] Calculated work ETU is 5.93 us reader mhz = 540
1970/01/01 02:32:24 10121720 r bla [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 5.40 Mhz (nearest possible mhz specified reader->cardmhz)
1970/01/01 02:32:25 10121720 r bla [internal] detect nagra tiger card
1970/01/01 02:32:25 10121720 r bla [internal] card system not supported
1970/01/01 02:32:25 10121720 r bla [internal] Normal mode failed, reverting to Deprecated Mode
1970/01/01 02:32:26 10121720 r bla [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
1970/01/01 02:32:26 10121720 r bla [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 02:32:26 10121720 r bla [internal] TEST tempo mhz check = 500 mhz
1970/01/01 02:32:26 10121720 r bla [internal] Calculated work ETU is 82.67 us reader mhz = 450
1970/01/01 02:32:26 10121720 r bla [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->cardmhz)
1970/01/01 02:32:27 10121720 r bla [internal] detect nagra tiger card
1970/01/01 02:32:28 10121720 r bla [internal] Resync error: readtimeouts 0/0 (max/min) us, writetimeouts 0/0 (max/min) us
1970/01/01 02:32:30 10121720 r bla [internal] T1 Resync command error, trying to reactivate!
1970/01/01 02:32:30 10121720 r bla [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
1970/01/01 02:32:30 10121720 r bla [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 02:32:30 10121720 r bla [internal] TEST tempo mhz check = 500 mhz
1970/01/01 02:32:30 10121720 r bla [internal] Calculated work ETU is 5.93 us reader mhz = 540
1970/01/01 02:32:30 10121720 r bla [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 5.40 Mhz (nearest possible mhz specified reader->cardmhz)
1970/01/01 02:32:30 10121720 r bla [internal] card system not supported
1970/01/01 02:32:30 10121720 r bla [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
1970/01/01 02:32:30 10121720 r bla [internal] card initializing error
1970/01/01 02:32:31 0 s init for all local cards done
Am incercat diferite setari in [reade], eroarea actuala data cu acestea
Code:
[reader]enabled = 1
label = bla
protocol = internal
device = /dev/sci0
caid = 183D
rsakey = A92............B5
ecmwhitelist = 91
ecmheaderwhitelist = 80308ED387,81308ED387
detect = cd
nagra_read = 2
mhz = 368
cardmhz = 2700
ident = 183D:000000,005411
group = 2
emmcache = 1,1,1
blockemm-unknown = 1
blockemm-g = 0
blockemm-u = 0
Vreo idee ??? Ca eu sunt depasit... :(
Cardul face lumina in camul lui sau in cccam (la acesta fara nici un fel de setare speciala). Intr-unul din cititoarele interne ale vu plusului mai am un HD+ 1843 care merge fara probleme....
Ms
