OpenPLi-4 Gstreamer 1.6.x (master git) VU+Solo/ Solo2/SoloSE Image
OpenPLi-4 Gstreamer 1.6.x (master git) VU+ Solo/Solo2/SoloSE Image
OpenPLi-4.0-GST1.7.1-vusolose-20160107_usb_sam NEW GST1.7.1
NEW GST1.7.1
Backup of original image by MastaG (thanx @MastaG )
NEW bootlogo / splash screen
whats installed
installed plugins:
-TSmedia 11.0
-ALbatros 3.7
-TSonlineTVMOD 5.3(updated new chs fix)
-iptvplayer 96.00.01.00
-crossepg 081 (rytec source updated & working 100%)
-Enhanced movie center
-mediainfo
-youtube_player
-Backupsuit
-BH xml/m3u convertor
-MSN weatherplugin
installed2 cams from feed:
cccam 230 & mgcamd1.38_srf , swiss chs works with keys included
livstreamer & lib/python & rtmpdump files for iptv streaming installed
(no need for any additional installation of packages from any plugin just skip it )
-recording & playing options works ok
-option set to media/hdd for the 1st usb media inserted
DRIVERS UPDATED 20151201
3skin installed
My-pli
Pli-HD-night
Pli-HD-M-MOD
ftb/telnet login:
name=root
passwrod=sam
OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
Please reflash your receiver since a software update will most likely fail.
Especially on spark/spark7162.
Changes since previous release:
- Gstreamer snapshot updated to 1.7.1:
* The mp4 issue when playing from remote locations has been fixed upstream, so I've dropped the revert.
* Libsoup has been updated so I've dropped the revert for the old libsoup as well.
- DM800Se V2 and DM500HD V2 kernel config has been cleaned and more in sync with PLi's config for the other Dreambox models.
- More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
* This should give us a few more MBs to work with (Dreambox *cough*).
- Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
* Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
* Enable of the zram module.
* Shipping his wifi drivers.
* VFD time is now synced every 5 minutes using a cron job.
* Software update and plugin-installation has been fixed.
* Using Tapaat's lirc config for spark and spark7162.
- The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
* A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
- Libsoup has been updated to 2.52 (from master-next).
- Refactor wifi drivers a bit on Linux 2.6.18, not auto-loading the mt7600 anymore, the correct driver should hopefully be loaded when you plugin your wifi stick.
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
Please use 'duckbox' instead.
- On Zgemma Star you cannot use full HD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes may behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
TODO:
- Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
- Linux 2.6.18: Look into the v4l usb drivers.
- Add Spark specific plugins by gorski.
- Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
Link:
OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-02-17
Hi folks,
It took me a while to build these because there were lots of small bugs and user requests.
I did my best to answer them all.
But due to my limited time I couldn't fulfill all of them, so my apologies if I didn't respond to a PM or forum-post.
So anyways.. there are lots of changes compared to my last images.
Too much for me to remember, so I guess:
- Added new receivers: Zgemma H5 and LC, Vu+ Solo 4K, XpeedC (whatever that is) and Atemio Nemesis (user-request, not tested at all so beware).
There are no Wetek builds and I ain't gonna build them, so don't ask.
- I've fixed the feed for mips32el-nf receivers (et4x00, hd1100, hd500c and xp1000).
- Oscam bumped to rev. 11211 with Joeuser's patch (yes I know you guys were waiting for this one).
- Lots of fixes for spark and spark7162 with the help of my great friend Taapat, they should be of equal quality as other PLi 4 images now.
The libeplayer versions are in the "eplayer" directory, everything else is gstreamer.
- No more patches to enigma2's servicemp3.cpp (except the one for aac transcoding), so it should reflect the current state now.
- Latest gstreamer 1.7.1 master head as of today.
- Many backports from master-next and Taapat.
- Lot's of small things I forgot.
Note:
- If you get corrupted jpeg images on spark/spark7162 the hardware decoder is not working for you, simply login using telnet and type:
rm -f /usr/lib/libmme_host.so
Then restart enigma2 and they should display fine
- Zram is now disabled by default on spark/spark7162, if would like to use it anyways, simply login using telnet and type:
touch /etc/gimme-zram
Then reboot your receiver.
If I didn't mess up badly this time, this will be my last round of public images.
I don't think there's any benefit for releasing gstreamer master head images anymore, since the next stable gstreamer release will hit master-next and oe-alliance anyways.
And most work went into supporting non-PLi-supported receivers which takes lots and lots of time.
Thank you all for the great feedback !
You're the best!
OpenPLi-4.0-GST1.7.2-vusolose-20160220_usb_sam
NEW GST1.7.2
whats installed
installed plugins:
-TSmedia 11.0 (updated latest-fix)
-ALbatros 3.9
-iptvplayer 102.03.06.00
-mediainfo
-youtube_player
-Backupsuit92
3skin installed
My-pli
Pli-HD-night
Pli-HD-M-MOD
ftb/telnet login:
name=root
passwrod=sam
DOWNLOAD:[Only registered and activated users can see links. Click Here To Register...]
