VU+VTi 9.0.1
VU+VTi 9.0.1
VU+VTi 9.0.2 Vu+ Uno Image
19.01.2016 - Urgent Information
Please check tuner configuration when tuners are in loop through mode.
It is not allowed to loop through a tuner multiple times
19.01.2016 - Software Update VTi 9.0.2
- increase image version: VTi 9.0.2
- update drivers (2016-01-19) (solo4k)
support Chromium OS
fix DiSEqC problem
improve power consumption
fix misc.
- add Chromium OS to image (including YouTube TV) (solo4k)
- update dvbapp2 (2016-01-17)
keep compatibility for extra headers in stream urls
MovieList: improve handling when leaving movie
MovieList: add option to hide entries
when start dir is set to all or new movies
Timeshift: add separate menu: Menu>VTi>Setup - Timeshift
Timeshift: map button STOP to live TV (timeshift recording is still in progress)
Timeshift: map button STOP LONG to stop timeshift
Timeshift: add function to transform timeshift to regular recording (Please note: short outage in TS file at transforming timestamp)
Common: add global option for dvbapp2 debug output
Menu>VTi>Setup - System
Common: support EPG and picons for 4097 services (e.g IP>TV)
Common: support recording of 4097 services (e.g IP>TV) -> THX @betacentauri
Common: fix handling of http timeout at streams
Common: fix button EXIT when infobar animation is enabled
EPG: add option to blacklist services for DVB EPG (EIT) updates
EPG: support for adding extra data to EPG events
- add plugin epgshare THX @einfall (ver. 0.01 20160117)
- add plugin tinyfoscamviewer (ver. 1.0)
- readd plugin mediatombplugin (ver. 1.0-r5)
- update plugin autoframerate
fix switching to 24p mode
- update plugin camofs (ver. 10.01)
- update plugin devicemanager2 (ver. 1.7)
fix partitioning for some devices
- update plugin graphicalmultiepg
support button mappings
support custom picon folder
- update plugin infobartunerstate (ver. 3.0.1 20160108)
- update plugin lcd4linux (ver. 4.7.-r2)
- update plugin multiquickbutton (ver. 2.7.14-r6)
- update plugin openwebif
switch to standby when transcoding starts (solo4k)
- update plugin picturecenterfs (ver. 7.03)
- update plugin seriesplugin (ver. 4.5.0 20151221)
- update plugin webradiofs (ver. 13.57)
- update skin atile (ver. 4.2-r0)
- update skin mutespectator (ver. 2.8)
- update skin stylefhd (ver. 2016-01-11)
- update opera hbbtv (2015-12-22) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
- update transtreamproxy</itemtext>
support infobartunerstate plugin
- update vtipanel (ver. 3.36)</itemtext>
add favourites list loader (see forum for howto)
Menu>Setup>Service Searching
- add package jpegtran-cffi
- remove xbmc from image (solo4k,duo2,solo2,solose)
20.01.2016 - Software Update
- update dvbapp2 (2016-01-20)
fix silly timer conflicts
add missing service info for 4097 streaming services
- update plugin devicemanager2 (ver. 1.8)
readd support for devices without single partitions
-update plugin hbbtv (YouTubeTV) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
keep compatibility for skins
- update plugin epgshare (ver. 0.1 20160120)
- update plugin infobartunerstate (ver. 3.0.3 20160120)
INFORMATION - 21.01.2016
Replace VTi 9.0.2 images in database : VTi 9.0.2 (2016-01-19) --> VTi 9.0.2 (2016-01-21)
21.01.2016 - Software Update
- update dvbapp2 (2016-01-21)
fix freezing mkv playback for some rare mkv types
fix black screen after framerate change
to activate plugin set:
Menu>Setup>System>A/V settings>Refresh rate: multi
22.01.2016 - Software Update
- update gstreamer1.0-libav (2016-01-22)
fix media playback with TrueHD audio tracks
23.01.2016 - Software Update
- update dvbapp2 (2016-01-23)
Timeshift: change default value for event change behaviour
Timeshift: take care for zap timer
- update plugin picturecenterfs (ver. 7.10)
24.01.2016 - Software Update
- update dvbapp2 (2016-01-24)
Timeshift: change default value for file remove intervall (default = 0)
fix dvbapp2 shutdown
25.01.2016 - Software Update
- update dvbapp2 (2016-01-25)
Timeshift: map function transform timeshift to REC button
Timeshift: remove duplicate menu entries
REC button: add transform timeshift to configuration choices
- update vtipanel (ver. 3.37)
fix image restore/flash tools
03.02.2016 - Software Update
- update dvbapp2 (2016-02-03)
Timers: fix repeating timers
Timeshift: enhance naming scheme for timeshift files
Timeshift: do not switch to live TV after event change
Timeshift: add option to to use < and > buttons for switching timeshift events
Timeshift: change default configuration for behaviour at event change
- update hbbtv (ver. 20151228) (solo4k)
- update skin mutespectator (ver. 2.9)
see TimeShift screen for new source TimeShiftService
05.02.2016 - Software Update
- update plugin camofs (ver. 11.0)
- update plugin fritzcall (2016-02-05)
- update plugin permanenttimeshift (2016-02-05)
keep compatibility to new dvbapp2 functions
- update plugin picturecenterfs (ver. 7.22)
06.02.2016 - Software Update
- update dvbapp2 (2016-02-06)
Common: fix releasing memory at loading epg data
- update plugin camofs (ver. 11.01)
07.02.2016 - Software Update
- update dvbapp2 (2016-02-07)
Timeshift: fix naming scheme of ts files
Timeshift: try to set correct file name for saved event
Timeshift: do not stop timeshift when channel selection will be closed without service change
- update gstreamer-plugin-dvbmediasink
fix sound dropouts at some media files
08.02.2016 - Software Update
miscellaneous bug fixes
fix AC3/DTS playback when PCM tracks are present
09.02.2016 - Software Update
- update dvbapp2 (2016-02-09)
[Timer] add option to avoid simultaneous timer starts
[Timeshift] add function to transform old timeshift events
[Timeshift] use begin time of event for ts file name
[Timeshift] add option to hide timeshift files in movie list
VU+Uno_VTI_9-0-3
16.05.2016 - Software Update
- increase image version: VTi 9.0.3
- update drivers (2016-05-16) (solo4k)
support FCC (Fast Channel Change)
support SD/HD transcoding in live TV mode ** Restriction : No Pip/MiniTV, Slow LCD Drawing
fix pluggable dual DVB-S2 problem when both A/B tuners are in use
Improve HDR
add proc entry to support some unicable equipments (needs a Solo4k Misc. plugin)
add proc encry for DVB-CI timing control (needs a Solo4k Misc. plugin)
fix misc. bugs
- update dvbapp2 (2016-05-16)
[Common] support FastChannelChange - THX @VU+ Please disable dvbapp2 console logging when FCC is in use(solo4k)
[Common] fix 0 byte recording issue in linked tuner - THX @VU+
[Common] save cached configuration before dvbapp2 crash based GUI restart
[Common] gracefull shutdown of dvbapp2 at changing run levels
[Common] simplify unicable configuration with suggestions
[Common] improve media scanner behaviour recognize also IPK files
[Common] rework Audio/Subtitles screen
[Common] add option to change services with CHANNEL +/- buttons
[Common] rework startwizard
[Common] add option to enable/disable crash screen - disabled by default
[MovieList] change modification time of files when removing to trash
[Timeshift] fix black screen bug for service change at same transponder
[Timeshift] change some default configuration values
[Timeshift] allow deleting files older than 6 hours
[IPKG] use software manager for installing packages
[IPKG] log errors and use EPG button to show collected errors after software installation
[Subtitles] use Vu+ changes for setup subtitles style
- update busybox</itemtext>
fix udhcp for some vlans
- update youtubetv/chromium (ver. 2016-05-16) (solo4k)
- update vtipanel (ver. 3.41)
[Common] change reboot behaviour after upgrade
[VTiZerO] fix removal of xbmc
- add kodi to download feed (ver. 16.1) (solo2, duo2, solose, solo4k)
- update plugin camofs (ver. 11.64)
- update plugin enhancedmoviecenter (git 20160510)
- update plugin fritzcall (rev. 1299)
- update plugin multiquickbutton (ver. 2.7.15)
add function to enable/disable every button
PLEASE check your configuration after update
- update plugin openwebif (ver. 0.4.7 20160509)
fix rare crashes with mediaportal plugin
- update plugin seriesplugin (git 20160409)
- update plugin tectimetv (ver. 3.0)
- update plugin webradiofs (ver. 14.45)
- update plugin yamp (ver. 3.1.1 2016-05-09)
- update skin atile (ver. 4.4-r0)
- update skin cerxfhd (ver. 20160403)
- update skin kerni-hd1r3 (ver. 20160221)
- update skin mutespectator (ver. 3.1)
- update skin stylefhd (ver. 2016-03-24)
VTi Image 11.0.0 Vu+ Uno Image
